swapped in a lower mile motor in my 97 wagon to daily drive because my original motor with 120k on it has a bad ring in the second cylinder. My plan is to run 6psi on the motor i just swapped in with a t25 and 12:1 fmu. But while running that i want to build the original motor for real power... so my question becomes a rather broad one, whats best way to go? Figure i should do something with compression and assume pistons and rods and probably a some bore/sleeves? Camshaft?
Looked around and see the 1.9 build below but know they arent the same in terms of build and capabilities. And been using jeffs cardomain like my bible for build but appears he hasnt done internal work or i missed it... I want a reliable motor that i can track and not blow up. I plan to just drive on occasion on weekends and want ability to drive it to track then run for the night and drive back...
Goal: probaly sounds stupid, but multiple friends with wrx's and one with an RX8 with exhaust/headers/intake that are so full of themselves i must beat them in my escort. I have a daily driver so this will be my sh#t grin car beating on a$$ holes in mustangs and subarus...
I know im asking alot, but hoping for a little more guidance if possible. Best route to go for good power but not blow motor apart at the track. Plan to run AEM management but hear megasquirt is better choice so not exactly sure yet...
Thanks very much for any help
Dale
Dale
