8-10 degrees BTDC is the base timing with the SPOUT shunt disconnected... it's the little gray or black plastic connector near the TFI module. Usually non-roller heads had 10 degrees as base timing, with roller cam models having 8. You can easily set it up to 12 or 14 if you want to run premium gas.
