1 - 8 of 8 Posts
Hey guys I need some help here bad, when I get on it at about half throttle and more running through the gears there is like a thumping coming from the right front and its pulling to the right some when im on it when Im not it goes straight. When I get on the brakes hard there is one big thump and the brakes are pulsating like its abs when I get on them too, I can take the passenger side wheel when its in the air and feel play when I go side to side with it but not up and down.
New Stuff...
Hub Bearing on the right side
Cv Shaft when I put the clutch in got it from a low miles car
Outer tie rod ends
Passenger side inner tie rod end
It started this after I got it all together from welding everything up about 20 miles after, the new hub bearing has only about 250miles on it. I just cant figure this one out, mechanic says cv shaft but it shouldent have play side to side in the hub.
Thanks
Curtis
I check all the mounts they look good, I jacked it up found my friend that tightend the tie rod end didnt tighten it enough just got it to where the cotter pin would go though, tightend it down and i can still take the wheel and woble it lugs are all tight it seems like the damn bearing is bad again. Cv shaft is still tight no tears in the boots, the hub isn't wobbling just the splined sleeve that the cv shaft goes through are though.
Thanks
Curtis
Now it feels like the front end is falling off pulling both ways, feels like lugs are loose but they arnt, cv shaft was fine just the boot had a hole still had grease put a new boot on tons of grease, took it out felt fine, changed the lower control arm on the drivers side ball joint was bad take it out and feels like everything is bad now i dont know what to do im about to just put it in 2nd put a brick on the gas and jump out :evil:.
Curtis
:evil: got it fixed jam nut for the pass tie rod looseded up, lower control arm had to be alot tigher than i was told, took it out drove good, took it out to put gas in it and get some stuff done and i cant go over 35 with out it shaking like its falling apart, and thats on the gas if im not it drives fine :?: any ideas? everything is tight and looks good or is new.
Curtis
Bad ball joint? Maybe your new wheel bearing blew out again? Wheel is bent? Tire our of balance? Did you somehow forget to reconnect the sway bar to the control arm? Axle nut coming off? I suggest checking everything with a bushing/bearing and make sure all is OK as well.
1 - 8 of 8 Posts
