1st gen escort performance | Page 7 | Ford Escort Owners Association (FEOA)
Discussion in '1st Gen 1981-1990 CVH' started by gt19ho, Sep 15, 2004.
  1. old86EXP
    old86EXP FEOA Member
    671
    166
    Alberta, Canada
    low is right it does get very thin there. I have an intake that I cut the top off and welded on a bigger plume. It takes any 5.0l throttle body. Never had it on a running motor so I can't say if it works or not. Could turn out to be a big waste of time. The linkage turned out to be a big headache. I took a bunch parts to make the 5.0l throttle body work.
  2. CAR75
    CAR75 New Member
    24
    NEED HELP with correct xr4ti ecm for 88 gt 5 spd 1.9 ho
    I am looking for a plug n play ecm for my 88 GT 1.9 ho 5 spd. I can get my hands on a xr4ti turbo 85-89 PF3. Is this what I would need? Looking for some hp gain. Does it matter if it is from an auto or manual?
    Thanks
    Anyone know if this ecu has a rev limit?
  3. Sketch
    Sketch You Tube Tuner-vana
    304
    4
    178
    Dyer, Tn
    If you ever plan to boost it then you want the maualecm because it has most stock boost.
  4. 1lowscort
    1lowscort FEOA Member
    3,066
    288
    Missoula, MT
    I am running an auto ECU in my red EXP running 18 PSI is just fine and good with it.
  5. Sketch
    304
    4
    178
    Dyer, Tn
    oops I meant the manual one. It was factory rated at a higher boost like fifteen stock I believe. Is the car you are putting this in auto or manual?
  6. 1lowscort
    3,066
    288
    Missoula, MT
    My EXP is a manual, in fact all of my Escorts/EXPs/Lynxs have been manuals, never owned an auto. I guess that is because I have only owned one LX and it happened to be a manual, the other 9ish have been GTs.
  7. diabloscort
    diabloscort New Member
    225
    antioch,ca
    whats up!!!!
    Whats up 1low!!!!!! i have tried to call u and nothing... i hope everything is well with u!!!! here is an updated pic of the scort but it looks even different from this pic.....
    [​IMG][/img]
  8. squirt
    squirt New Member
    83
    Kingsland, GA
    hey diablo i really like your car. i was think about putting just that bumper on mine. do u know what injectors will work on my 89 1.9HO.
  9. va89GTescort
    va89GTescort New Member
    134
    Culpeper, VA
    Thanks this is really help full sadly though last year my cuzin sold a Murker for about 500 bucks but it was a complete car just without the top end of the motor
  10. Sketch
    304
    4
    178
    Dyer, Tn
    boost
    ok bump
    :wink:
  11. Shackelford
    Shackelford New Member
    7
    I was reading your post below and have a couple questions for you or anyone. I am looking in to buying a 1988 EXp with a 1.9. Is this similar or the same as the escort gt of that year? Or what is the difference? Does the 1.9 of the Exp put out 88hp or 127 hp? Would the Merkur ECU work on the Exp and are you still able to get those? Thanks for any info you can provide me!
    Aaron
  12. twobit
    twobit FEOA Member
    367
    22
    168
    Portland,OR
    I believe the exp is pretty much identical engine, drive-train, suspension, everything but the body itself equivalent to that year escort.
    if it has the 1.9L EFI H.O. it would be 110hp stock. if its the CFI engine its going to be less. the Merkur ECU is only swappable with the EFI H.O. engine.
  13. Sketch
    304
    4
    178
    Dyer, Tn
    ya I believe he is right and yes they are still available because all the guys with the merks are going for the la3 computers my self included.
  14. Shackelford
    7
    Ok so the GT fell through, now I'm looking into a 1.8 from a 91 escort. I have a 1995 lx wagon and the 1.9 is on its way out. I'm trying to find a way to swap in more power with a limited budget or i"ll have to just get the 1.9 head reworked and put it back together. Would the 1.8 bolt in in place of the 1.9?
  15. 1lowscort
    3,066
    288
    Missoula, MT
    Many troofs have been spoken.
  16. Sketch
    304
    4
    178
    Dyer, Tn
    whatcha talking out willis?
  17. jswilson1987
    jswilson1987 FEOA Member
    47
    6
    will a weber dgev bolt up to a 82 1.6 intake?
  18. Sketch
    304
    4
    178
    Dyer, Tn
  19. Diane
    Diane FEOA Member
    657
    35
    278
    The 88 EXP was called Escort EXP and did not have the HO. It's one of the reasons I didn't buy one.
  20. huck731
    huck731 Well-Known Member
    153
    If i am reading this right, i can jusy plug and ay the xr4ti or early t-bird ecu onto my 89 lx without any other modifications?
