1999 ford escort se transmission questions | Page 2 | Ford Escort Owners Association (FEOA)
Discussion in '3rd Gen 1997-2002 2.0L SOHC' started by dirtking, Nov 12, 2019.
  1. dirtking
    dirtking FEOA Member
    25
    I also noticed that the absolute throttle position was at 20% sitting at an idle. Is that normal?
  2. 04Svt
    04Svt FEOA Member
    697
    206
    103
    The short term fuel trims sound to be ok. They do bounce back and fourth. If it was like 20 to 25.0 that would be a indication of the computer compensating for something wrong.
  3. rbailin
    rbailin FEOA Member
    1,232
    364
    333
    Concentrate more on the long-term fuel trims, which will stabilize the more you drive the car. Actual fuel trim is the sum of the long+short term trims, and the ECU keeps a table of trims based on speed range and throttle position, IIRC. After resetting the ECU by disconnecting the battery, the long term trims start out at zero, then get adjusted according to the trend of the short term trims in order to minimize the fluctuation of the short term trims at each speed. All 3 of my Escorts ran in the +5 to +15% lt trims due to minor air leaks.
    Keep an eye on the engine temp. Make sure it gets up to operating temperature (190-195) within 5 miles after a cold start. It could run consistently cool (170) without you noticing it on the temp gauge due to a bad thermostat, leaky thermostat gasket or (sometimes) a bad bypass check ball in the thermostat housing.
  4. dirtking
    25
    Ok I will watch that stuff. Hopefully the miles per gallon come up. Still seems like there is a miss or something slightly off. With the code reader I will try to narrow it down to an rpm range
  5. zzyzzx
    14,681
    1,077
    Probably close enough. I checked 4 different vehicles and the numbers were in the low single digits to around 20%
  6. dirtking
    25
    Ok seemed kind of odd that it was that high.
  7. dirtking
    25
    I replace the pcv valve and the hoses related to it. So far the code has not returned yet. I still seem to have a stutter/ miss through the rpm range, but no check engine light. I have replaced fuel pump, fuel filter, spark plugs, spark plug wires. Anybody have any other ideas?
  8. 04Svt
    04Svt FEOA Member
    697
    206
    103
    How’s the transmission fluid? Dirty ? If it is I would replace filter and put new fluid .
  9. dirtking
    25
    Also a new air filter. It doesn’t look terrible but isn’t brand new either. I have that on my list to do. Best fuel mileage I have had so far is 28.
  10. dirtking
    25
    Looking up the transmission filter and it lists a shallow and deep pan. Do you guys know the dimensions to tell the difference?
  11. 04Svt
    04Svt FEOA Member
    697
    206
    103
    There is no deep pan . The bar that bolts in wouldn’t if the pan was larger. I never understood why they ask that.
  12. dirtking
    25
    ok thank you for all the help! What oil do you recommend?
  13. 04Svt
    04Svt FEOA Member
    697
    206
    103
    Mercon 5
    Where ever u can get the best deal.
    Prob walmart
  14. dirtking
    25
    Ok thank you!
  15. Swampscort
    Swampscort FEOA Member
    62
    24
    8
    This exact issue happens on my 99. I've had a 97 manual for 20 years. So when I rescued this little 99 with the at the little bumps in and out have been driving me crazy thinking it's slipping(trans juice was in dire condition when I got it). Hopefully when you change that trans filter you can get the support bar out of the way, mines rusted in place which makes getting the pan off a rather sporty bit of wrenching.
    And I've been getting the IAC code too. Going to see if a new pcv fixes it.
    Gotta love weird "common" problems!
  16. Pizzaman5000
    Pizzaman5000 FEOA Donator
    1,452
    429
    183
    Central OH
    Try putting the old PCV back in if you have it. I know this is a 3g, but 2g's are SUPER picky about pcv brand. It's basically a pre determined vacuum leak/EGR mix.
    My 91 won't idle with an AutoZone or advance brand pcv. Like period.
    Lop, lop, stall.....
  17. Gamer92
    Gamer92 FEOA Donator
    3,423
    973
    263
    Southern Indiana
    you can drop the pan without removing the bar
    you'll just have to jack the trans up a bit and use a small wrench for 3-4 of the pan bolts, takes a bit longer but it can be done
    denisond3 likes this.
  18. denisond3
    9,912
    2,677
    Or you can devote a 3 day weekend to getting the front-to-rear support bar removed. I did it with my oxy-acetylene torch, and a lot of time (a desperate weekend).
    Joey_Twowagons likes this.
  19. dirtking
    25
    I have changed the transmission filter and fluid. I have put about 100 miles on it since then and I still have the stutter/miss. Seems to be at about 3000rpm. Also haven’t have the p1506 code come on until tonight. Might have to just get the new IAC valve.
    I will have to look and see if I have the old PCV valve. I believe I threw it away.
  20. dirtking
    25
    Anybody else have any other ideas? These cars pretty noise for valve train? Seems pretty noisy even with a new rebuilt head.
    Thanks for all the help and advice
