1999 Escort SE shakes and shuts off | Ford Escort Owners Association (FEOA)
Discussion in '3rd Gen 1997-2002 2.0L SOHC' started by jrw928, Apr 3, 2015.
  1. jrw928
    jrw928 FEOA Member
    21
    4
    My 99 Escort SE sedan just shook real bad and shut off while in reverse yesterday. After starting it again it shook but then I put it in drive and started moving and it was fine. I know that the valve seats (I think thats what they are called) are going because the car has a clicking noise coming from the engine. So my question is, Is this shutting off from the valve seats or could it be something as simple as a tune up? I change the oil every 3000 miles but I have not yet done a tune up on the car. I have owned it since november of 2014. Any help is greatly appreciated!!
  2. bent_rod
    bent_rod FEOA Donator
    1,566
    229
    213
    Kansas City
    An intake valve seat drop is a major defect that can cause a destroyed engine.
    I recommend getting a compression test done on the engine.
  3. jrw928
    jrw928 FEOA Member
    21
    4
    I took the car to a mechanic before I had the shut off issue. I was told that it is the seats thats how i know. I was told that I will be able to get a few thousand more miles before needing to do any major work. Ive just been putting Mystery Oil into the oil every few hundred miles and it has run good and the clicking is low. So what is this shut off issue?
  4. 22732
    22732 Guest
    If it is indeed a failing valve seat(s), that will result in low compression which could result in stalling. Also if it is for sure a failing seat that is clicking, it could go at any moment which will result in severe engine damage. It would be cheaper to have a new head put on the motor now rather than later. But only a compression test can tell you if the ticking is actually a valve seat going and not just a noisy lifter.
  5. jrw928
    jrw928 FEOA Member
    21
    4
    Ok so would an engine diagnostic consist of the compression test? I know I can get an engine diagnostic test done at Midas for $45.
  6. 22732
    22732 Guest
    You would have to call and ask them. That may only consist of hooking up a diagnostic machine to the computer. I wouldn't know for sure as we don't have any Midas' around where I live.
  7. bent_rod
    1,566
    229
    213
    Kansas City
    Midas = muffler shop, Firestone = tires & battery shop and same for all the other national chain outfits.
    Please, do yourself a favor and take the car to a well respected local auto repair shop for the engine compression test.
    zzyzzx and Gamer92 like this.
