1 - 3 of 3 Posts
Hey there this is my second post. My battery light on my 1999 Ford Escort just turned on today. The battery was recenetly replaced. What could the problem be? I read it could be the alternator but my manual for the car says electrical component needs servicing, what do you think? Also as I recently posted my car made this weird "clicking sound" coming from the area of the alternator so maybe it is that? Thanks
· Super Moderator
it's definitely a charging system issue. check the connections on the battery and make sure they are tight. sometimes wiggling them makes the light go off, but in your case it may be alternator replacement time.
IF you have a volt meter an easy way to tell if the alternator is bad is by reading the voltage from the battery terminals while the car is running. A healthy alternator should give you a reading of about 14 volts.
1 - 3 of 3 Posts
