1 - 3 of 3 Posts
engine has complete loss of power in first gear bogs down, no engine cpu codes, fuel pressure perfect, took off cadolitic converter drove it around still no engine power only has power at about 2000 rpm, engine appears to have low compression 60-70 psi per cylinder only 95000 miles on engine is there a valve seat problem with these cars or is it somthing to do with that timing auto adjust near cylinder number 4
yes sir, i tried dry and wet it stayed the same, next thing im going to check is timing see if the belt jumped a tooth or do you know anything about that auto adjust timing.
1 - 3 of 3 Posts
