1 - 2 of 2 Posts
Greetings all
My wagon has 130k on it. Check eng light on looong time.The codes are 0171,1130,1131 and 1443. 1.9 eng. The car has been running rough and also starts to over heat.Guage goes up to about 3/4 then comes back to about 1/2 way.Any help on wher to begin would be appreciated.
thanks in advance
randor
From the 1.9L trouble code chart - OBD-II system
as printed in the Chilton Ford Escort/Tracer 1991-99 Repair Manual:
  • 0171 - System (adaptive fuel) too lean (Bank #1)
  • 1130 - Lack of upstream Heated Oxygen Sensor (HO2S 11) switch, adaptive fuel at limit (Bank #1)
  • 1131 - Lack of upstream Heated Oxygen Sensor (HO2S 11) switch, sensor indicates lean (Bank #1)
  • 1443 - Evaporative emission control system - vacuum system, purge control solenoid or vapor management valve malfunction
....hope that helps ya!
As for where to start... I'd suggest picking up either the book I quoted or the appropriate Haynes repair manual for your car. :D ...or, if you're not comfortable doing it yourself, befriend a mechanic and/or find a reputable one in your area.
1 - 2 of 2 Posts
