1995 ford escort turbo project ecu question | Page 3 | Ford Escort Owners Association (FEOA)
Discussion in 'Forced Induction & Nitrous' started by slammed escort 95, May 20, 2014.
  1. slammed escort 95
    slammed escort 95 FEOA Member
    47
    18
    So I got the spi head installed I am having to modify the stock intake manifold to fit the 1.9 fuel rail because I could not find a 97 spi with a fuel rail that had return so that has been a little bit of a pain I am however pretty happy I got a set of 19 lb mustang gt injectors that fit perfect and plug right in.
  2. slammed escort 95
    47
    18
    how much boost can I run with just an fmu
  3. ShakeZilla19
    ShakeZilla19 My name is ^^^
    3,172
    666
    363
    Depends on your FMU. Anything over 10psi is dangerous with an FMU.
  4. slammed escort 95
    47
    18
    so I should probably only run like 8 psi to be safe
  5. ShakeZilla19
    3,172
    666
    363
    Re-read you have a 12:1 FMU. You can boost alittle more with those(still under 10psi) but I would stay around 5psi for awhile and monitor things. Do you have gauges set up?
  6. Jeffescortlx
    Jeffescortlx FEOA Member
    8,421
    13
    338
    Minnesota
    You will make more power with a stock 9:1 1.9 SEFI at 6 psi then you will with a low compression hybrid motor at 8psi.
    You done goofed. Put the stock head back on... or get some real engine management.
  7. slammed escort 95
    47
    18
    so I need some help I installed my fmu I do not have the turbo on yet but started the car just to check for fuel leaks the fuel return line is leaking where it connect to the fuel rail seems like even with zero boost the fmu is building to much pressure
  8. slammed escort 95
    47
    18
    hey man its been a minute question will it make a difference if my mass airflow is installed on the turbo intake side or should it be on the pipe going into the throttle body
  9. twisted95
    twisted95 FEOA Donator
    537
    30
    178
    charleston
    be lot easyer with a megasqurit stall a lone system running boost have full control of edis timming
  10. ShakeZilla19
    3,172
    666
    363
    It does not matter in the sense that car will run either way. You want the MAF to be away from the TB but not to far.
  11. slammed escort 95
    47
    18
    Hey man I have a question I'm trying to hook up my electric fan the fan has two wires and the harness on the car has the wires in sure there is a way to hook this up any input would be awesome
  12. twisted95
    537
    30
    178
    charleston
    shoud be 3 wires ground low speed high speed
  13. slammed escort 95
    47
    18
    OK so I should just hook them up and see which way the fan spins when it gets up to temp and with a complete connection the temp sensor should work right
  14. twisted95
    537
    30
    178
    charleston
    looking to to wiring see what go where
  15. twisted95
    537
    30
    178
    charleston
    i know on the 1.9s the ecu controls fan
  16. slammed escort 95
    47
    18
    So I have finished my spi head swap I have everything hooked up all vacumn lines but the car seems to idle pretty low between 300 and 500 rpm is this normal for this low compression build your input would be greatly appreciated
  17. ndlm8888
    ndlm8888 scortin daily
    989
    351
    213
    tampa bay ,fl
    Check all vacuum lines/ports. Everything must be pluged in. Pics would be great
  18. slammed escort 95
    47
    18
  19. ndlm8888
    989
    351
    213
    tampa bay ,fl
    Aright I see your problem. The pcv connector at top of intake manifold has 3 connections the top has vacuum but to two coming out does not have vacuum. Those r for to cool the pcv usually has coolant running thru them. Those vac lines need to go to where u have it plugged at.
  20. slammed escort 95
    47
    18
    so can i just cap those two that are not vacumn
