so i am doing this swap and its almost done but i need some help. there is a sensor thingy (sorry i dont know what its called) that goes on the new gtx motor that i dont know where it plugs into. it looks like the one that goes to the VICs. its black. i dont know where it plugs into. on the gt fuel rail there is that vacuum line, where does it go? when repining my ecu for 4 wire tps do i count the wires straight across to the other plug or the same plug ?(referring to http://www.feoa.net/modules.php?name=Fo ... ic&t=30034) sorry not to bright on the subject. needs some help please! thank you. http://s274.photobucket.com/albums/jj26 ... guitarist/
