1995 Escort 2 dr LX help | Ford Escort Owners Association (FEOA)
Discussion in '2nd Gen 1991-1996 1.9L SOHC' started by TrustJesus, May 13, 2013.
  1. TrustJesus
    TrustJesus FEOA Member
    38
    18
    Possibly buying a 1995 escort. I have a 1992 escort 4 door that recently went bad when the strut mounts rusted thru. Are the parts on these two cars interchangeable?
    Also, the owner of the 95 said he thinks the inner tie rods are bad "play in the steering". Would that mean the rack/pin would need to be replaced as well? Is it easy to change out the inner tie rods on this model?
  2. 2doorLX
    2doorLX FEOA Member
    51
    158
    St Louis, MO
    Most of the parts are intercahangable from 1990 to 1996. The tie rod ends can be changed, but have a mechanic look it over to prevent issues.
  3. zzyzzx
    15,177
    1,223
    The OE outer tie rod ends on these cars go bad by 50K miles. If left too long they will tear up the inner tie rod ends as well. My strut mounts rusted through, but the body of the car was not damaged.
  4. TrustJesus
    38
    18
    Were you able to fix the rusted strut mounts?? If so, how? Any pics?
  5. zzyzzx
    15,177
    1,223
