1 - 5 of 5 Posts
:x I have a 91 Gt with a 5 speed. The problem I'm having is the car pulls to the left when i let up on the gas to shift to the next gear. The higher the engine revs the more severe the pull. The steering components seem tight yet, I replaced 2 mounts that were pretty well rotted (front and rear) and the others seem fine. I have tried different struts and springs from another escort. The CV joints seem ok. There is no eneven tire wear. I'm getting frustrated. If anyone has any suggestions I would greatly appreciate some advice. Thanks
Dont hold me to this. But I would check the lower control mounts. I have a 89 thunderbird with the independant rear suspension. And when the bushings on the lower control arm wear, I get a simalar thing. Under accelleration, the arms actually tilt out a bit and swing back in when you decellerate. As I said at the first of this, I could be wrong. But it is easy to check.
1 - 5 of 5 Posts
