1990 HO intake on 2nd gen motor | Ford Escort Owners Association (FEOA)
Discussion in 'Engine Tuning' started by twisted95, Nov 1, 2011.
  1. twisted95
    twisted95 FEOA Donator
    537
    30
    178
    charleston
    i have looked at almost all the post on the 90 ho intake on 2nd gen. has any one got a pic what needs to be done for it to fit?
  2. madmatt2024
    madmatt2024 FEOA Member
    9,824
    393
    383
    Upstate N.Y.
    The port spacing is different so there is no easy way around it. Basically, you need to cut the flange off both intakes and weld the 2nd gen flange onto the HO intake. I have seen the pics but can't find them.
  3. UnexplodedCow
    UnexplodedCow FEOA Member
    7,030
    171
    363
    Central Ohio
    Matt is correct, the port and bolt spacing don't really line up. The bolts will kind of fit, but the design blocks off some of the port. Besides that, the stock intake on the 2nd gen should be plenty sufficient for the small port head used.
    There is one alternative: use the CFI intake from a 1st gen, make some injector bungs, and then have what is essentially an unbalanced short runner intake, with a 40mm throttle body.
  4. twisted95
    537
    30
    178
    charleston
    i have both intakes port are way diff from the 2nd gen ... i think of soomething
  5. UnexplodedCow
    7,030
    171
    363
    Central Ohio
    Interesting you say that, because I've test fitted a 1st gen CFI manifold from a 1st gen onto a 2nd gen head and the bolts, ports, and water jacket all line up.
  6. rangestang
    rangestang FEOA Member
    427
    26
    I think he is talking about the H.O. intake
  7. twisted95
    537
    30
    178
    charleston
    i took the gasket for the ho intake. then laid 2nd over it parts little diff bolt holes are the same
  8. diabloscort
    diabloscort New Member
    225
    antioch,ca
    bigger intake for 1.9L
    whats up.. i have done this swap and its pretty involved... i took a HO lower manifold and cut the flange that bolts to the head... i then took a SEFI intake and cut the flange off of that and i pieced it together so it will line up with the individual ports... alot of welding and porting and it netted a little gain... the SEFI head is the poopiest head in escort line up... the intake works way better with the HO head...
  9. twisted95
    537
    30
    178
    charleston
    diabloscort do u have a pic of this mods intake lot of port work need to be done?
  10. diabloscort
    225
    antioch,ca
    yes i do but u have to think about the coolant passage that is right there under the TB..... i will have to find the picks... i still have the lower intake that i made... now that i am finishing up on my 2.0L HO build... i started with what ur thinking and if you get a good look at ur intake ports on ur head, u will see that the intake runners r not for flow due to restriction... the combustion chambers r the smallest that i have seen in an escort.... if i find them, i will post them for u...
  11. twisted95
    537
    30
    178
    charleston
    took me little time to fab it all to fit just would like to know if it hit the hood or sturt bar coolant passage that is right there under the TB block off plate and now temp gauge
  12. Guest
    Guest Guest
  13. twisted95
    537
    30
    178
    charleston
    spam????
  14. juggalo
    juggalo New Member
    6,096
    9
    Tacoma, WA
    lol, a bot posted spam and a moderator removed it
