1989 turbo escort still kicking after 3 years | Ford Escort Owners Association (FEOA)
Discussion in 'Forced Induction & Nitrous' started by rix415, Sep 6, 2007.
  1. rix415
    rix415 Guest
    282
    Been a while,
    took out my turbo motor/head and put in a stock motor in 2005?
    I got an RS setup with a SVO LA3 computer & sensors.
    plugs are white (eek) but i'm about to get it tuned up
    the compression is still 180-170 across the board.
    I'm going to dyno soon for a benchmark, then a tune - should be ~200whp by then. I'll keep you posted
    in the mean time i can only do burnouts in first gear :(
    enjoy,
    -Mark
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  2. win0857
    win0857 FEOA Member
    1,117
    4
    288
    Connecticut
    Cool,another turbo 1st gen.What state are you located in?
    mark
  3. rix415
    rix415 Guest
    282
    Michigan, south of detroit.
    how the hell are you pulling that ET?
    i should go to the track, i haven't been there since i put it all together in 2003.
    everyone usually laughs :)
  4. BOSS302man
    BOSS302man FEOA Donator
    2,665
    44
    198
    Lebanon, PA
    I'll take a wild guess, MI?
  5. win0857
    win0857 FEOA Member
    1,117
    4
    288
    Connecticut
    Yea,i get laughs also,but when i run side to side with a wrx or beat a duramax with BOOKU $$$$ invested it stops.Traction owns us front wheel drive's but 23 psi of boost helps!
    It's for sale as i am building a 88 and could use the $ for the "new"escort build!
  6. BTR-GT94
    BTR-GT94 New Member
    518
    Monroe, MI
    Where you at in michigan, i'm in Monroe.
  7. S-scort-Wagon
    S-scort-Wagon FEOA Donator
    1,267
    186
    his location... detroit area
  8. jamesm
    jamesm Guest
    1,085
    you have LSD in that thing?
  9. neuspeedescort
    8,126
    98
    348
    wenatchee, wa
    good to see your still around!
    NEUMAN
  10. rix415
    rix415 Guest
    282
    Im in taylor now.
    NO LSD, just got a new set of PILOT tires. They ran a little higher than normal but they hook up great and i can't seem to get a 'one tire wonder' burnout anymore unless i'm flying around a corner.
    think i might have just figured out why i might be having problems with leaning.
    im running the escort regulator instead of the 2.3L turbo ford regulator. At 0 vac our regulators sit at 38-40psi? after that its a 1:1 boost vs fuel pressure raise rate? I don't think our regs sit at 38 psi or have a 1:1 - i almost want to rig up the other regulator just to eliminate the possibility of it being different.
    going to miland dragway for test and tune soon, anyone wanna come? I don't think ill have time between now and then to fix the regulator but i want to run for fun. gotta beat my old goal of 16 seconds :)
  11. rix415
    rix415 Guest
    282
    nevermind, just got back from the parts store - same damn regulator
  12. win0857
    win0857 FEOA Member
    1,117
    4
    288
    Connecticut
    Buy a after market regulator for a mustang gt.It is the same and bolts right up!!That is what i am using on the 86,i bought it on ebay.
    mark
  13. Jeffescortlx
    Jeffescortlx FEOA Member
    8,421
    13
    338
    Minnesota
    Good to see your still around and boosting that 1g.
  14. jigsaw
    jigsaw New Member
    1,803
    wow, thats a nice car. it's rare to see a 1st gen where i live
  15. rix415
    rix415 Guest
    282
    GREAT NEWS
    JUST GOT DONE INSTALLING THE WIDE BAND AND DIGITAL GAUGE AND ITS NOT LEANING OUT AT ALL
    14.7 ~ 15.1 idle and 12.8 up to 11..A/F!
    even seen a few 10's!!
    so - i don't know why the plugs are white. I'd guess there is some case that causes it - or a period when i had something messed up (its been 3 years).
    overall though I haven't had enough time to really understand its behavior completely but DAMN it is great to know your mixture with a decimal point!
    will try to get a video of a pull if i can tonight. I'm not sure what is to rich and what is to lean? i know i want 12.something and thats about it.
    im going to the dragstrip with my buddy tomorrow (with a car dolly) and try to get the ET down with some timing and boost (since i know im rich i can add some boost and/or timing)
    SO SLIPS TOMORROW
    (my 60ft is gonna be 3 sec)
    (im going to lapeer dragway around 4pm till like 8pm if anyone wants to show)
  16. 4doorscort
    4doorscort New Member
    8,129
    5
    Brampton ON
    i'm not a big fan of 1st gens, but that things pimp!
  17. Jeffescortlx
    8,421
    13
    338
    Minnesota
    It has louvers, of course it's pimp.
    louvers = hotness.
  18. vtec-this
    vtec-this FEOA Member
    1,577
    6
    288
    Brampton Ontario
    what heat range of plug are you running? Stock heat range sure aint any good at 16psi.
  19. rix415
    rix415 Guest
    282
    i need to replace plugs and wires.
    im not sure what to get, any suggestions?
    never made it to test and tune, turns out lapeer stops that at like 4pm - good thing i called before trailing out there.
    im running 5-10 psi (turbos so big it depends on rpm) now - thinking about just unplugging the wastegate line to see what it does
    since i couldn't get my fix i spent all yesterday pulling on and off sidestreets so i could see how fast i could pull from 0 to 45 (stupid laws) and i just couldn't get the tires to break loose on their own. i dont know if im just not putting out enough power or my tires are that good. its a crap shoot until i go to the dyno or the track.
    Think im going to buy a tweeker RT so i can monitor my computer and change the tables.
    had the car filled up with 6 gallons of 110octain so i started advancing the timing. got to little past halfway - i caught some deto (clap clap clap, about time) riding out first gear at 35-45. i need to return it to 10-12 BTDC and not do that again... ever..
    the la3 computer should put our over 200 whp. my A/F is actually a little bit to rich (when you think you should really be in the butter zone) it goes past 11.1 and into 10.9-10.5 (usually past 5000rpm)
    so, i think its gonna be a little bit longer till im making the power i can make. need to use real plumbing instead of pvc pipe and copper pipe fittings.. it just needs to be gone though again - and the mounting of my VAM is really bad - the engine vibrations must be messing with the reading (or so im told by everyone) - next month ill have some vacation time, see what i can pull out of it then.
