1987 LYNX XR3 (ESCORT GT) Cranks But No Start | Ford Escort Owners Association (FEOA)
Discussion in 'Tech & Repair' started by GT Dreamer, Oct 14, 2020.
  1. GT Dreamer
    GT Dreamer Well-Known Member
    61
    Long time admirer of the site....and need the advice of fellow Escort fans.
    Have a 1987 Mercury XR3 (aka Escort GT) that I bought earlier this year. After some initial work....new timing belt, draining the tank, cleaning out the fuel lines, installing an NOS fuel pump....it started and ran just fine. Then I parked it outside where it has sat for 9 months. Too much going on with family, work, 2020 etc.
    With work demands slowing down, I finally got some time to give it attention and begin work on a full restoration. The old battery was dead...so I bought a new one. Started right up and idled for 20-25 minutes then died. Wouldn't restart. Cranked but never fired up again.
    Had fuel so checked ignition coil and it showed no spark.
    So far I've replaced with new parts....ignition coil, distributor cap & rotor, spark plugs & wires. Looks to have a spark now...cranks fine, but still not firing up. Will check fuel pressure next.
    Any advice or suggestions would be appreciated.
  2. Valdres Rose
    Valdres Rose FEOA Member
    26
    17
    North Dakota
    Are you sure that your timing belt is ok?
  3. 88ESCORTV6
    1,282
    266
    333
    Hawkesbury Ontario
    Timing belt, TFI module...it's on distributor. start with this.
    GT Dreamer and austin86 like this.
  4. austin86
    1,103
    358
    118
    Ohio
    I second what 88ESCORTV6 said. Also check for codes on the EUC if you can.
    GT Dreamer likes this.
  5. zzyzzx
    15,209
    1,230
    Try one of those spark checkers.
  6. GT Dreamer
    61
    Thanks for suggestions guys. Replaced ICM on distributor....still no start. Fuel pressure check out ok. Timing belt was replaced in January and looks good. Spark seems to be almost intermittent.
  7. austin86
    1,103
    358
    118
    Ohio
    timming pill ok? what about the 2 wires going to the master?
