15" 16" or 17" 3rd gen | Ford Escort Owners Association (FEOA)
Discussion in 'Wheels/Tires/Brakes' started by DanDidIT, Feb 18, 2017.
  1. DanDidIT
    DanDidIT FEOA Donator
    36
    9
    68
    Upstate, NY
    I see any of these sizes will work fine to maintain the factory diameter. Any thoughts on which route to go if getting new summer tires/wheels? Of course, the 15s are cheapest... but they may be a tad small looking by today's standards. Was thinking of going 16" Thoughts?
  2. Tnashua
    Tnashua Gearhead / hot rodder with a soft spot for Scorts
    1,045
    235
    213
    Oskaloosa, IA
    I like the looks of my 17"s, never had a set of 16"s, but liked the appearance of the 15" ZX2 wheels I had on my Black Tracer back in the day... :) The 17"s make the car corner better, but you feel the bumps (every bump...and rock... etc.) Some of us have had issues with rubbing too. If you don't get a factory wheel- be sure to get the right backspacing/offset or you may kick yourself later. Show us what you decide! :)
  3. DanDidIT
    36
    9
    68
    Upstate, NY
    Thanks for the details. I agree the 17" wouldn't be the best for a car you plan to drive a lot. I'm really between 15 and 16. Still working it out...
  4. DanDidIT
    36
    9
    68
    Upstate, NY
    Anyone running a 205/50 16? I'd like to get a bit more height as compared to a 205/45 16, if it will fit without rubbing.
    It looks like a stock 185/65 14 is about 23.5" in diameter and 7.3" wide, while the 205/45 16 has 24.1" diameter and 81" wide.
    Thanks
  5. pextor
    pextor Moderator Staff Member
    5,939
    802
    Lancaster, pa
    I love my 15s.
  6. cklaubur
    cklaubur Former Escort Owner
    1,748
    41
    298
    Now in Mesa, AZ
    @DanDidIT: My Focus has 205/50R16's. If you'd like, I can do some measuring of the wheel/tire combo for you.
    Casey
  7. DanDidIT
    36
    9
    68
    Upstate, NY
    Thanks, I'm good for now... was just wondering what everyone's preference was
  8. novanutcase
    novanutcase FEOA Member
    2,517
    597
    263
    17" x 7" - I wrapped them in 205/40/17 tires. No rubbing issues.
    [​IMG]
    18" x 8" - I wrapped these in 205/40/18 tires. Rubbing on hard bumps or when I had a heavy load in the back.
    [​IMG]
    John
    Tnashua likes this.
  9. DanDidIT
    36
    9
    68
    Upstate, NY
    Thanks John. Looks nice. I do see you have the rear DBs on in the first picture. What rotors are you running?
    I also just noticed that your car is satin black. What paint did you use? Does it clean up well?
  10. The Stoner Wagon
    The Stoner Wagon New Member
  11. 4cylinder
    4cylinder FEOA Member
    696
    126
    193
    san diego, ca
    i have a set of 16" wheels on my 99 and use 195 45 up front and 205 50 in the rear. neither rub or have any clearance issues. i am probably going to change out the fronts to match the rear but i just wanted to try out both sizes and see how they did.
    on a 3rd gen 4 door or wagon 15" wheels will look good from a zx2. 2003 wheels or 99 s/r wheels would be the coolest but any 15" zx2 wheel would look and fit good on a 4-door or wagon
    what is your location?
  12. DanDidIT
    36
    9
    68
    Upstate, NY
    upstate NY
  13. novanutcase
    2,517
    597
    263
    Lowering springs.
    John
  14. novanutcase
    2,517
    597
    263
    Slotted and drilled. I rattle canned the paint job. I've done a few rattle can paint jobs and have learned a few good tips as to how to get it to look decent. PM me if you need help.
    John
  15. DanDidIT
    36
    9
    68
    Upstate, NY
    Do you know the brand and how are they with corrosion? I'm looking for a good quality rotor that resists corrosion so they look presentable.
    Your paint job is impressive. I would not have known that was a rattle can. There's a few brands that are better than others for large areas. Gotta do it in the shade when it's cool out.
  16. novanutcase
    2,517
    597
    263
    Out here in Cali not much rusts since it's usually so dry so it's hard to say how they are with corrosion but I would say probably most are comparable to each other since the blanks probably all come from the same foundry in China and get finished here. Short answer? Their probably isn't a difference between them in regards to the metallurgy and corrosion resistance. Also, while rust may form on the face of the rotor the moment you apply the brakes all that rust will disappear.
    I used a paint can sprayer tool so that my fingers wouldn't get tired and I wouldn't rush the job. I also bought some different spray tips with different spray patterns. I got 4 or 5 per spray style so that I could tailor it to different parts of the car and change out the tip when it starts to clog. I kept a cup with paint thinner handy so that I could just pop the tip off and drop it in the cup to let the tip soak. Some people try and clean out the tip with a needle but that just changes the spray pattern so as soon as it starts to clog I pull the tip off and drop it in the thinner since the paint in the tip is still soft enough for the thinner to penetrate. Tight areas like door jambs get the tight spray pattern and the larger areas like hood and body panels get the wider spray pattern. Prep is almost more important than the actual spraying of the paint so be sure you get everything as smooth as possible before you spray it. Don't skip prep steps like wiping down with grease remover before you paint it.
    John
    Tnashua likes this.
  17. wasthatawagon
    wasthatawagon FEOA Member
    711
    39
    278
    Atlanta GA
    Love the way 18's look on these small cars
  18. DanDidIT
    36
    9
    68
    Upstate, NY
    do you know the specs on those wheels: width and backspacing?
  19. novanutcase
    2,517
    597
    263
    18" x 7" with a 35mm backspace if I'm not mistaken but those particular wheels are not easy to find as they've been discontinued.
    John
  20. DanDidIT
    36
    9
    68
    Upstate, NY
    Thanks - do you know what the backspacing is?
