1. What turbo do they come with stock?
2. Does anyone have a compressor map?
3. What is the stock comp. ratio?
4. Is the turbo a T3 flange so I can bolt my T3/T04e up to it?
5. What injectors do they come with?
6. What's the stock timing set at?
7. Are lower compression pistons available? (If it's higher than 8:1 to start with)
8. What are the stock connecting rods capable of handling HP-wise?
9. Does anyone make a header/log-style manifold?
10. Is there much excess material to port in the stock manifold?
11. Does anyone have a dyno chart of a stock engine?
12. Is the rev-limiter the same 7200 as the EGT?
13. Even easier than answering the previous twelve, does anyone have an in-depth website on it? I can't seem to find one.. then again, I am really dumb.
P.S. I decided to stop being a cheapass mofo.. I'm now a paying member. HOLLER.
