marclar said:
alright guys... the other day i filled up with 108 octane and cranked the MBC up. i was able go hit 12 psi without deto or blowing up the SPI. however i WILL NEVER DO IT AGAIN, it almost made me piss my pants. 1st gear was useless because it just burnt out and made me grind 2nd realy bad. but 2nd gear was absolutely NUTS!!!. however... the fuel pressure was only at arround 90 psi.
Well, 90psi of fuel pressure is'nt too bad.
Did the fuel pressure raise consistinly with the boost pressure?
I'm getting knock at 8psi with 93 octane, I'm really suprised 108 octane alone with no timing retard is enough with 12psi.
Have you heard ping from your motor before and do you know what to listen for? It's quiter then most would think.
Congrats 8) I can promise you, you will do it again. It's hard to go back once you feel the power. Just use caution.
EDIT: You might only see 90psi because that might only be as high as the fuel pump will go. If I remember right I could only get 80-90psi from my stock fuel pump. Just kink off the return line with the car running and see how high the fuel pressure goes.
