12 volt high-amp switch (non-relay) ? | Ford Escort Owners Association (FEOA)
Discussion in 'ICE (In Car Entertainment)' started by needWheels, Aug 2, 2011.
  1. needWheels
    needWheels FEOA Member
    520
    4
    118
    I'd like to kill all power to my amps and inverter when the car is off because it sits for a week at a time (without having to go under the hood with a battery switch).
    Does anyone know where I can get a high amp switch that is freestanding and not a relay but direct (so it's cheap and reliable).
    Switch "only" needs to handle 25amps max, I have small amplifiers.
    Not sure what to search for, cannot find anything suitable (that's cheap).
  2. Benlightnd
    Benlightnd FEOA Donator
    703
    38
    278
    Missouri
  3. neuspeedescort
    8,138
    101
    363
    wenatchee, wa
    ^ that will do it. however i don't see what the point is. i have had my car sit for longer then a week and never had power drain issues. that is with an alarm on also.
    NEUMAN
  4. EscorGo
    EscorGo FEOA Donator
    3,006
    139
    213
    Wichita, KS
    I don't understand why you need it either but Radio Shack would have what you want.
  5. needWheels
    520
    4
    118
    I wanted it because the voltage is always 11.9-12 volts in my car after a week of sitting and I suspect it's my old amps causing a light drain. Should be closer to 13.1 right?
    This is even with a brand new battery.
    So this would be a cheap solution.
  6. neuspeedescort
    8,138
    101
    363
    wenatchee, wa
    the last car i have a voltage meter in i would se low 12's after just sitting over night. driving around it would be in the low 13's. so in the 11's after a week isn't bad.
    NEUMAN
  7. FordMan59
    FordMan59 FEOA Member
    4,556
    446
    333
    Russellville, Kentucky
    You could probably pick up a high amp switch at any auto parts and maybe even in the automotive section of Walmart.
  8. racethisescort89
    racethisescort89 New Member
    2,391
    In your closet watching you secks!
    12.4 is usually what they run at when engine is off. no need for fancy switches and junk.
  9. needWheels
    520
    4
    118
    It is very bad for a lead-acid battery to sit at lower than optimal voltage for even just several hours, the plates start to sulfate.
  10. neuspeedescort
    8,138
    101
    363
    wenatchee, wa
    oh yeah i forgot to take into account not everyone has a gel cel battery. then yes your battery is going to be effected. however.....if its such a big deal why not just disconnect the battery ground?
    NEUMAN
