1 - 8 of 8 Posts
it cranks over but no primage of fuel pump or signal to ecu.
Do I need the wiring harness that runs through pass. fender that goes to soliniods, coolant resivour, and air bag sensors, or what about that baby blue box thing thats near the ECU.?
Former Escort Owner
The blue box is for the airbag system.
The wiring harness is completely different between the 1.8 L engine and the 1.9 L and the 2.0 L. You would probably have to change the complete harness to match the engine and computer.
Casey
werd thanks for the help! what is the unit that is under driver seat? i have the one from my LX. Should i take out the GT one and put in the LX?
So you think i need a whole fuse panel from an LX (drivers Knee)?
Started pulling wring harness through the pass. side had to pull out that big black box (heater-core). Then it goes up and behind the other big box in the center its a beeeeyatch
:roll:
Check out the www, the lx motor is turboed makes cool noises has gauges I got 3 BP motors after I get this project done ill start to turbine the BP ultimately would like to get GTX 4x4
1 - 8 of 8 Posts
