1.9 HO cam, will it fit into a 2.0L SPI? | Page 3 | Ford Escort Owners Association (FEOA)
Discussion in 'Engine Tuning' started by Adlorin, Oct 22, 2007.
  1. 1lowscort
    1lowscort FEOA Member
    3,066
    288
    Missoula, MT
    CFI definately has smaller valves the the HO. I have both of them sitting in my storage unit.
    CFI
    [​IMG]
    [​IMG]
    HO
    [​IMG]
  2. PonyExpress
    PonyExpress New Member
    4,128
    indeed it does. my Ford techdata is wrong then.
    hard to believe that the SPI valves are even larger than the HO, where'd they get the room? well i spose if the cc was larger...hmm
  3. UnexplodedCow
    UnexplodedCow FEOA Member
    7,042
    177
    363
    Central Ohio
    As mentioned above, you can get 1mm larger intake and .75mm larger exhaust valves for the 1.6 head, which will fit into the 1.9, provided the seats are enlarged as well. That would make the valves about the same size as the SPI. However, since the SPI is a D chamber head, I wonder if it actually flows as well since the valves are a bit more shrouded than the HO head. Maybe it doesn't even matter.
  4. 95EscortDriver
    95EscortDriver FEOA Member
    1,181
    186
    Hubert, NC
    WOW! I'm glad I read this post. You know the white piece that goes in the clip for the CPS? Yeah, mine disappeared on the last head replacement, so it's held together with Electrical tape... So my car sometimes sputters at idle... now I'm thinking that the connector might be loose.
    Thanx!
  5. jet-lee
    jet-lee Guest
    780
    celery - Reading Comprehension, Ignorant, look them up.
    Pony - Thanks for the info.
  6. PonyExpress
    4,128
    welcome.
    one thing ive learned over the years with this car is to keep as much stuff stock or in as close to stock running or operating condition as possible.
  7. 95EscortDriver
    1,181
    186
    Hubert, NC
    The cool thing is that there is alot of stuff that can be changed using other vehicles parts. Keeping something stock can be boring. Modifying it can be desatorous, (sorry, bad spelling) The thing to figure out is the line between the two to have a [email protected]$$ car!
  8. PonyExpress
    4,128
    when i say keep things stock.. im not saying dont modifiy the car at all..
    honestly.. MSD wires and coil pack didnt do squat for either of the 2 escorts i had them on.. eventually causing issues with both of them..
    stock plugs, wires and coil isnt boring.. it works. no need to upgrade really.
    the things i say to leave stock arent going to make a badarse car if modified anyway..
    people are tweaking temp sensors, cutting out cats, sticking platinum plugs in, etc... and none of that helps, usually ends up with a post in the engine tuning section about why it isnt running right..
  9. 95EscortDriver
    1,181
    186
    Hubert, NC
    Totally agree with ya. If your gonna do it, do it right. Unless, the parts to keep you from frankensteining your car are not availible, then you do what you can at YOUR OWN RISK! Now, I don't exactly mean not to turbo the motor, or not to Hybrid it (1.9/2.0 SPI, .... ) Just driving it seems a little boring. On the other hand, don't cry when your SCREW it all up!
  10. PonyExpress
    4,128
    exactly..
    you dont know how many times over the years id do something to one of my cars.. think "aw yeah! this is going to be awesome!"...
    only to have to put it back to stock to see if the problem that came up then goes away.. and it does..
    i guess thats why automotive engineers get paid so much for those fancy degrees.
  11. 95EscortDriver
    1,181
    186
    Hubert, NC
    I don't think your following me on this one.
    I mean to say, I don't disagree with modifying your Escort, shoot! I plan on modifying my own. What I'm saying is don't expect it to work perfectly afterwards. They were built the way they were for a reason, when modifying things, they break. Like with a Honda, my friend has been through 4 motors doing his "Trial and Error" method with his SOHC Turbo project, and he expected to go through a few. Now that he's learned from his mistakes he's made, made the adjustments to fix the problems modifyied this and that for upgrades, now he's ready to build his motor for the power he's putting into it and hopes the motor blowing days are over. And yet, even though you build the crap outta it, its still going to go eventually. all cars die eventually!
