1 - 2 of 2 Posts
Have a buddy with a 95 tracer 1.9 Auto , he needed to know what the ATF fluid capacity , i cant seem to find my repair manual , can anyone hook me up with the Spec ? thanks
Jeremy 98 Lx
The haynes book says 2.5 qts. Thats for a filter and refill. Theres also a drain plug that allows more to come out. If you know the level is fine before you do the change, pour the old fluid into a graduated gallon container and only add that amount back in. Its easy to overfill an automatic transmission. The upper level on the dip stick is for when its been driven for about an hour. not 5 or 10 minutes.
1 - 2 of 2 Posts
