1.6 '83 Escort, what's possible? | Ford Escort Owners Association (FEOA)
Discussion in 'Engine Swaps' started by AnalogLife, Jan 10, 2020.
  1. AnalogLife
    AnalogLife New Member
    Philadelphia
    Hey all,
    I've been driving an '83 1.6L for a bit, didn't take much to get the original engine back in shape. Turns out I've got a cracked cylinder head now, and I'm looking at my options to give it some new life without putting another 80's 1.6 in it. It's a first half '83, 4-speed FWD. I see a lot of talk of zetec working natively on the GT trans, just wondering if it's worth finding and cannibalizing a GT to put some more power in it.
  2. austin86
    756
    242
    58
    Ohio
    a 1.9 HO head should fit on a 1.6l. But I would keep it a 1.6l and import a cam from the UK and UK 1.3l pistons if you want power. The 1.3l pistons will have more compression, you can put a webber carb on it to if its a carbbed car. like the 38 outlaw or 32/36 but its not a drop in carb, you will need to drill out the bolts holes in the carb for it to line up with the manifold.
  3. novanutcase
    novanutcase FEOA Member
    2,514
    591
    263
    Did the 1st gens come with MK motors because if they did you will have a host of go fast parts to bolt onto that engine although I'm not sure what it would cost to get them over here.
    John
  4. austin86
    756
    242
    58
    Ohio
    the US 1.6l is very similar to the UK 1.6l, some parts can be used wile others can't be used.
    Cams are know to work from what I seen and I believe pistons too. Not sure about intake parts like dual webber manifolds.
  5. novanutcase
    2,514
    591
    263
    Too bad. The 1.6's with velocity stacks look sweet!
    John
  6. AnalogLife
    Philadelphia
    So I recently found a clean '97 escort with the 2.0L, 5 speed for super cheap, as it was totaled in the rear. Engine's got low miles, any ideas on how difficult that might be to convert?
  7. novanutcase
    2,514
    591
    263
    Convert to what? Most people(me included) swap in Zetec engines from ZX2's for 3rd gens('98 - '03). From what I just found out your '97 has the old style fuel return system whereas the 3rd gens have returnless but you can swap out the fuel rail and make it work.
    John
  8. AnalogLife
    Philadelphia
    My bad for not clarifying, I'm wondering how hard it would be to completely redo the 1st gen with the 97 engine and trans. My exhaust and fuel tank on the 83 are near the end of their lives as it is, so I'm not opposed to doing those all new too.
  9. claych
    claych FEOA Member
    8
    Excellent thread !!!
    Subscribed :)
  10. novanutcase
    2,514
    591
    263
    Your '97 engine is probably an SPI. You'd have to reposition the motor and tranny mounts to stab it into the engine bay. Wiring would also be a concern.
    John
  11. madmatt2024
    madmatt2024 FEOA Member
    9,849
    410
    383
    Upstate N.Y.
    An SPI should technically bolt into a 1st gen and mate up with the 1st gen trans, they are both CVH's. It would be easier to mate it up with a 1st gen trans than to make the 3rd gen/SPI trans work. Even then you will still have to get the fuel injection to work.
  12. novanutcase
    2,514
    591
    263
    Good to know. Thanks!
    John
  13. Car Tales
    Car Tales New Member
    If you guys are in the bay area Retrosporting is a good place to reach out to if you need help with your Escort build, you can find all their contact info on Instagram. The owner is a good friend of mine and we recently did a video together on his RS2000 Tarmac Spec rally car build, thought you guys might like it.
  14. Joey_Twowagons
    Joey_Twowagons FEOA Member
    2,379
    1,094
    Vancouver Island, Canada
    The video won't play for me. Maybe because I'm in Canada?
  15. Joey_Twowagons
    2,379
    1,094
    I refreshed the page and the video worked.
    A beautiful car, and a great video!
    Our later Escorts are not quite so exciting.
