'02 2.0SOHC Parts on '96 1.9 SOHC
1140 Views 5 Replies 5 Participants Last post by  madmatt2024
Hello,
As seen here: ( http://www.feoa.net/modules.php?name=Fo ... ic&t=60850 ) I have a blown 2.0 sohc engine. In addition to that '02 scort, I also have a '96 LX with a 1.9 in it.
So, just trying to figure out, what parts, if any, can i swap on to my 1.9 that might improve performance? From what I have read, it sounds like the intake is not boltable. Would the throttle body be boltable and/or make a difference? Are the injectors from the 2.0 any better and/or would they swap in?
Thanks in advance!
~Carl
1 - 6 of 6 Posts
The throttle body may be bigger but I would measure both before I swapped it. Injectors are bigger which the computer isn't calibrated for so don't swap them.
The tb is the only thing you can use as a performance gain.
Another Blown 02 2.0
I have a 02 scort with a bad 2.0. The yard is tellin me the motor needs to be out of a 00-02. I want to know if this is true and if so why? Any help would be greatly appreciated.
False. It can be from any 97+ Escort. If its from a 97 you will have to swap fuel rails.
1 - 6 of 6 Posts
