1 - 5 of 5 Posts
Discussion Starter #1
Hey guys how are you doing, I have a 2001 Ford Escort ZX2 I noticed last night when idling the car started to creep towards the hot/H (usually it stays straight up) on the temp gauge while idling. Before this I was doing some highway driving and driving around the town for a little bit but the gauge looked fine as I was driving .I recently replaced the coolant thermostat/ housing an both lower an upper housing sensors. I do know that if you unplug the top connector the fans kick on high. When i am idling in traffic or at a stoplight the fans don't turn on Any ideas?
The relay for the fan is in the constant control relay module (CCRM) which is located under the air cleaner intake.
  • Like
Reactions: zzyzzx
Check the cooling fan fuse in fuse box near battery. I think it is a 40amp.
Could also be the relay like pex mentioned
1 - 5 of 5 Posts
