Vibration Problems.
Discussion in '2nd Gen 1991-1996 1.9L SOHC' started by FordEscorter, Mar 1, 2010.
  1. FordEscorter
    FordEscorter New Member
    508
    Im at my wits end here. There car still vibrates. Even worse when i put it in gear (foot on the brake).
    Here is a youtube vid of it
    http://www.youtube.com/watch?v=ugHj_ViP5gI
    I have done the following.
    1. Replaced every motor mount.
    2. Replaced the wires, the plugs were clean
    3. Did a vacuum test, check out good.
    4. Did a compression test, all were in range.
    5. Cleaned the piss out of the Idle Air Control Valve.
    but there is no muffler on it right now. Could it be resonating and cause the motor to vibrate?
    Please help
  2. dave8338
    dave8338 FEOA Member
    927
    168
    Annandale, MN
    Wellllll...that does seem a bit excessive! 8O
    Did you replace the motor mounts with urethane mounts?
    If so, that is part of the problem.
    If not, about the only things I can think of that will cause that kind of vibration is a torque converter that is out of balance (they have been known to shed a weight) or a bent crank.
    I highly doubt you have a bent crank. ;)
  3. FordEscorter
    508
    Im going to check and retighten the motor mounts tomorrow.
    I think it could be.
    1. Bad Harmonic balancer.
    2. No muffler
    3. Timing belt was replaced and was put on with it being off a notch.
  4. dave8338
    927
    168
    Annandale, MN
    Yeah if the damper pulley is bad, she'll dance. (could be why they put it on there in the first place)
    If your timing is off, that will throw things out of wack, as well.
    Anything else you forgot to mention? Have a dead cat stuffed in the intake? Bag of marbles in the oil pan? :?
  5. FordEscorter
    508
    No lol.
    Its the timing belt part of the harmonic balancer.
    Can the harmonic balancer go bad at 136,000?
  6. the1nicko
    the1nicko New Member
    230
    Radiator mounts, upper and lower.
  7. FordEscorter
    508
    thats not gonna cause the whole car to shake.
    the motor vibrates. the rad. doesnt
  8. Dave94LX
    Dave94LX FEOA Donator
    5,787
    238
    Under the Stairs
    your video says that you haven't replaced the crossmember yet. 2 of the mounts are mounted to that crossmember, so if you haven't fixed it yet, then those 2 mounts cannot possibly do their job.
    Replace or fix the crossmember, and it should fix your problem.
  9. FordEscorter
    508
    see the funny thing is it didnt vibrate when the crossmember was taken out. so something in the engine is vibrating, bolting the crossmemeber back up transfered more of it into the body.
    awnser me this.
    1. could having no muffler shake the engine from resonation?
    2. Would a bad harmonic balancer show up more at low rpm?
  10. dave8338
    927
    168
    Annandale, MN
    1. NO
    2. YES
  11. FordEscorter
    508
    how hard is it to remove?
  12. the1nicko
    230
    I had the same problem with the whole car shaking especially when it was in drive at a traffic light. I realized one of the bolts on my upper rad mount was missing and replaced it. It went away. Worth a shot? I think so. The engine is connected to the radiator via two hoses and cooler lines(auto). If the engine vibrates, the radiator vibrates. The radiator mounts are connected to the body, bad or loose radiator mounts will cause the whole car to vibrate. A worn harmonic balancer could cause vibration at idle but should increase as the rpms increase. You mine as well start with the cheap stuff that requires less labor.
    [​IMG]
  13. FordEscorter
    508
    steering wheel doesnt shake
  14. the1nicko
    230
    OK, but the car shakes at idle correct? You clean the IAC, but refuse to change the radiator mounts? You say you changed the motor mounts but technically you missed 4 of them. You see where it says "These loads are transferred through the engine and body"? Maybe you just need a new air filter. :roll:
  15. FordEscorter
    508
    the air filter is brand new.
    where can i get the rad mounts?
  16. the1nicko
    230
    The air filter was a joke. I would at least take yours out and inspect them. I would call Ford and see if they still have them, if not try to find some good ones at a JY if you think they need to be replaced.
  17. FordEscorter
    508
    how can i tell if they need replaced?
  18. the1nicko
    230
    Just check the condition of the rubber, if you can locate them I'd just replace them anyways.
  19. FordEscorter
    508
    what do they cost?
    i still cant see how they can shake an engine
  20. Intuit
    Intuit FEOA Member
    6,998
    671
    313
    Southwest Ohio
    Needlessly replaced my clutch disc and at the same time thought it would be a good idea to replace the flywheel. WRONG (again)
    The flywheel I got from a Smyth Autoparts (Parts+ dealer) was WWAAYY out of balance. Shook the whole engine from the transmission side. Luckily I was able to get my original flywheel back.
    Fortunately or unfortunately, however you see it, this doesn't seem like your problem either. But maybe there's a chance you haven't mentioned something.
