Engine SPI head on Zetec block, pistons
Discussion in '3rd Gen 1997-2002 2.0L SOHC' started by DatsunGuy, Feb 1, 2017.
  1. DatsunGuy
    DatsunGuy FEOA Member
    22
    4
    Its came to my attention that I will just have to get a Zetec block for my SPI rebuild. No SPI's in my yards that don't have dropped seat damage. I don't want the low compression from using the zetec pistons, could I just put SPI pistons on the zetec rods? Also, could I plug the zetecs extra oil return holes with JB weld or the like, so I won't have to press brass pins in and have the block shaved? Kinda doing this in the cheap, I just want my car running
  2. Gamer92
    Gamer92 FEOA Donator
    3,017
    793
    213
    Southern Indiana
    Where are you located?
  3. DatsunGuy
    22
    4
    Louisiana
  4. Gamer92
    3,017
    793
    213
    Southern Indiana
    Is there Damage to your block? These engines can be rebuilt for around 6-700 bucks
  5. DatsunGuy
    22
    4
    A crake in the deck from overheating. I already sent most of my budget in a new head and all seals and gaskets, don't have much left for a rebuilt block. My junkyards sells short blocks for $100, but none of the 7-8 spis are any good..
  6. Gamer92
    3,017
    793
    213
    Southern Indiana
    Not all valve seats destroy the blocks.
    You may be able to find one on eBay
  7. DatsunGuy
    22
    4
    I used my bore score and the cylinder walls are shot, usually on #4, sometimes all. I been checking eBay no luck yet
  8. ShakeZilla19
    ShakeZilla19 My name is ^^^
    3,078
    604
    263
    Why not just swap to a full Zetec? It is a quick, cheap, and simple swap. The flow comes from the head not the block. You get 20+ horses right off the bat with none of the franken motor crap. The waterpump will also need to be modified.
    Youve prob read this but here..
    http://www.quantums.info/zvh.htm
  9. DatsunGuy
    22
    4
    I really should have just done that to start. But went dumb and bought a new SPI head, modded focus intake mani and loads of gaskets and such before searching out a block. And trying to sell off the SPI stuff wouldn't even get me half what I have into it, not that there's many people lining up to buy SPI stuff..
  10. Gamer92
    3,017
    793
    213
    Southern Indiana
    pap.PNG Are any of these cities close to you?
    DatsunGuy likes this.
  11. DatsunGuy
    22
    4
    Those are 3-5 hours south of me, was looking like that would be my best bet but, just found a 95 1.9 that looked to have been in great shape, just a hour north of me. No dropped seats, car was rear-ended. Now, I know that will put me at 8:1 cr, but I DO have a lot of turbo parts laying around, and before my car blew I had been wanting to boost it. Hmmm.... be a juvenile and boost my daily, or be reasonable and keep it stock/mild. The low comp should make it pretty safe and reliable on low boost I would think
