Engine PLEASE HELP THIS ONE HAS ME SCRATCHING MY HEAD!
Discussion in '3rd Gen 1997-2002 2.0L SOHC' started by BKZOWN, Feb 8, 2017.
  1. BKZOWN
    BKZOWN FEOA Member
    356
    87
    58
    Brooklyn
    ok guys so I haven't been on the forums in a while forgive me in advance lol. but anyway my escort has a little over 170k miles on it now. I haven't driven the car in a few weeks due to the fact I was waiting for a new thermostat housing gasket and new bolts to fix a little leak but that's all taken care of now. so as I went to drive the car I could feel something wasn't right with the escorts idling. the car was racing almost as if power breaking. highest idle was at almost 3k rpm which was when in park or neutral. when in drive the idle still raced but wasn't as high but I had to keep my foot firmly on the brake so the car wouldn't take off. the car went to hot also due to the high rpm not moving. then as soon as I shut it car wouldn't start. I let the car sit a few hours went to start it and everything was fine until I hit the gas pedal then the crazy high rpm started again so I shut her down. has this ever happened to any of you guys?? id suspect a sticking throttle plate or bad idle air control valve. please if any help let me know.
  2. cwol97401
    cwol97401 FEOA Member
    181
    46
    88
    Midwestern Oregon
    I've never had this happen. My first thought though is to check all of your vacuum lines and sensor connections. Double check.
    Tapatalk
    BKZOWN likes this.
  3. Gamer92
    Gamer92 FEOA Donator
    2,885
    749
    213
    Southern Indiana
    Check engine light on?
    Did you unplug the tps sensor while replacing the housing, if so was it plugged back in?
    BKZOWN likes this.
  4. buzzyj
    buzzyj FEOA Member
    170
    4
    178
    Binghamton, NY
    Might it be a sticking gas pedal cable, or maybe the spring that returns it? Just trying to be helpful!
    BKZOWN likes this.
  5. 04Svt
    04Svt FEOA Member
    112
    21
    18
    Check the coolant temperature sensor Connection.
    If the wire is damaged or the connector plug is messed up and not intact it will race with high rpm as described..also will be hard to stop if driving the car.
    The coolant sensor is the 2 wire connection on the thermostat housing. The one wire sensor next to it is for the temp gauge in the cluster.
    BKZOWN likes this.
  6. ShakeZilla19
    ShakeZilla19 My name is ^^^
    3,071
    601
    263
    your last line is a good place to start, sticky TB. Could also have a vacuum leak somewhere behind the throttle body: TB gasket, intake mani gaskets, IAC gasket.
    BKZOWN likes this.
  7. pextor
    pextor Moderator Staff Member
    4,702
    300
    233
    Lancaster, pa
    this is the most important question. If the light is on, it's at least trying to tell you something is wrong.
    BKZOWN likes this.
  8. BKZOWN
    BKZOWN FEOA Member
    356
    87
    58
    Brooklyn
    Gamer no check engine light on which I wish there was so I can at least have an idea to what is going on. I didn't disconnect the throttle position sensor. Took out the iac and cleaned it and nothing changed. I have to recheck my wires going to the sensors again how ever I would think a wire would automatically throw a check engine during start up self checks
  9. BKZOWN
    BKZOWN FEOA Member
    356
    87
    58
    Brooklyn
    Thanks shake I have to check when the weather gets better sucks bc my escort is usually my daily driver in snowy winter months bc it's awesome in the snow. I have to check bc this problem is driving me nuts. Should also mention the car is hard to start when the engine is warmed up. Cold starts are fine and so is the idle until you hit the gas pedal
  10. BKZOWN
    BKZOWN FEOA Member
    356
    87
    58
    Brooklyn
    Thanks I've tried this as well gas pedal isn't sticking
  11. thetubeamper
    thetubeamper FEOA Donator
    17
    Pennsylvania, USA
    I've got to agree with 04Svt and say it could be a coolant temp sensor, especially now that you mention it starts fine cold but not warm.
    04Svt likes this.
  12. Pizzaman5000
    Pizzaman5000 FEOA Donator
    1,129
    265
    93
    Central OH
    Do you have exhaust leaks? Have you checked for vacuum leaks with a flammable aerosol yet?
    I've seen symptoms like this with a blown intake gasket.. It had other symptoms, like no power brakes, but it would do highway speeds with no throttle. Half of the time it would barely stay running. Could be a leaking brake booster too.
    I ask about exhaust leaks because of o2 sensors and egr. Neither can deal with exhaust leaks in the wrong places. It's Sunday, give us as many clues as possible lil
  13. rbailin
    rbailin FEOA Member
    938
    179
    293
    For the engine to idle at 3k rpms, there has to be a pretty large air leak at or beyond the throttle plate. It can't be the intake manifold gasket because the leak comes and goes. Same goes for the o-rings for the fuel injectors.
    There are only a few places for air to get into the intake manifold:
    1. The vacuum hose port for evap under the throttle body. This hose rots away.
    2. The PCV elbow where it connects to the manifold. This elbow rots away.
    3. The EGR valve. If the gasket were bad, it would leak all the time. If the valve sticks open occasionally, unplugging its vacuum hose would stop that. But exhaust gas isn't a good source of fresh air for the engine, a leak usually stalls the engine at idle.
    4. The main vacuum port on the passenger side. Supplies vacuum to the brake booster, fuel pressure regulator, EGR and heater controls. Disconnecting and capping this port would eliminate all those sources of leaks.
    5. The Idle Air Control valve. When you unplug the connector, I'm not sure if the valve closes or remains where it was.
    Do some prep work so that when the engine is racing at 3k, you can disconnect and quickly cap either the PCV or the main vacuum port and see if the idle drops to normal. You can also try removing the IAC valve with the engine running and plug the holes with your fingers, which should stall the engine.
    I'm assuming that the throttle plate isn't sticking open and that you've tried opening and closing it by hand without making the idle drop below 3k.
    copcarguy likes this.
  14. copcarguy
    copcarguy FEOA Member
    1,363
    484
    183
    Northeast PA
    Just throwing this out there:
    When my car sometimes has a wonky / high idle I clean the MAF with CRC MAF spray. If my car is "angry" it'll have an idle north of 2K rpms.
    Very annoying when it happens.
