Parts interchangeable with mustang
Discussion in '1st Gen 1981-1990 CVH' started by trevynmason, Apr 12, 2017.
  1. trevynmason
    trevynmason FEOA Member
    22
    I've been looking around and are the parts from the first gen escorts and the mustangs from the same year interchangeable such as body panels shocks etc they look very similar.
  2. nineteeneightyeight
    nineteeneightyeight FEOA Member
    341
    39
    178
    Holgate, Ohio
    I think maybe the door lock knobs and turn signal bulbs interchange!
  3. dchawk81
    dchawk81 FEOA Member
    3,121
    793
    173
    Everything is interchangeable if you have a mig welder.
  4. nineteeneightyeight
    341
    39
    178
    Holgate, Ohio
    Also some lug patterns for the wheels are shared, of course the 4 lug only.
  5. zzyzzx
    13,046
    609
    The brake light switch (the one behind the brake pedal) might be the same.
    nineteeneightyeight likes this.
  6. zzyzzx
    13,046
    609
    Cruise control servo is probably the same.
  7. UnexplodedCow
    UnexplodedCow FEOA Member
    6,880
    61
    348
    Central Ohio
    Seats and seat rails.
    Headlight switch and bulbs.
    Door handles
    Seat bels
    Hand brake lever
    TFI module and ignition coil
    Several sensors can work, but may need calibration. Basic temp sensors/idiot lights should work.
    Alternator
    Starter and relay
    Door hinges
    Basically, a lot of little parts can be swapped between the two. A Merkur has more in terms of front suspension, since it basically uses what a 1st gen does (swaybar acting as tie bar for the single-bolt lower control arms).
  8. dchawk81
    3,121
    793
    173
    The Ford emblem is a direct swap.
  9. dchawk81
    3,121
    793
    173
    Model & trim emblems too if you're ghetto/white trash enough.
  10. copcarguy
    copcarguy FEOA Member
    1,483
    535
    213
    Northeast PA
    There was a kid in my high school that did exactly that. He had a white 1st gen GT, and replaced EVERY Escort emblem with a Mustang one.
    Then INSISTED it was a Mustang.
    zzyzzx and dchawk81 like this.
  11. UnexplodedCow
    6,880
    61
    348
    Central Ohio
    I knew people like that in my high-school. One guy kept calling his Dodge Omni a Mustang (no joke).
    Others would just put (for example) SS badges on their crappy base-model Cavalier. One person put Type R badges on a truck, if I remember correctly. Stupid teen stuff.
    I myself had Cadillac hub caps on my Caprice wagon. It was bought that way.
  12. trevynmason
    22
    Yeah I know it's not a mustang and I'm not gunna treat it like one. alls you have to do is pop the hood and it's missing a few cylinders. But I was just curious cause parts are more available for the mustang than for the escorts so if panels and such swap over they're easy to find
  13. UnexplodedCow
    6,880
    61
    348
    Central Ohio
    Some Mustangs from that era came with a 2.3L N/A engine.
  14. Tnashua
    Tnashua Gearhead / hot rodder with a soft spot for Scorts
    787
    151
    103
    Oskaloosa, IA
    I toyed with the idea of swapping some Mustang Effects to the old GT a long while back... Parked it next to a Mustang GT & snapped some picts & photo shopped it. (I'll look for the files sometime- they aren't on this computer...) That is as far as that project ever went! ;) Like dchawk81 said- If you've got time & a good welder (and some decent autobody skills)- you could make it happen...
  15. Tnashua
    787
    151
    103
    Oskaloosa, IA
    Found this one on my fb page... :)
  16. trevynmason
    22
    I know the the mustang is a bit longer wheel base than the Escort but the Escort is wider, and I believe they are the same height
  17. UnexplodedCow
    6,880
    61
    348
    Central Ohio
    Mustang has a wheelbase of 100.5". Escort is 94.2". In between that is Tempo, around 98.4" if I remember.
    Track width has the Mustang at ~ 3" wider than the Escort. I know this, because, around 2007, I started writing down plans, checking specs, and trying to gear up for swapping in a Fox drivetrain to my '90 LX, converting it to RWD. Life had drastically different plans, with me just getting a 2010 GT instead, which is honestly the better car.
    The easiest swap would be from a Merkur, since it has an IRS, RWD, and an otherwise Escort-based front suspension. An XR4-TI would be a good donor car, as the Escort would be shorter, lighter, and is built upon a strikingly similar platform. Granted, the Merkur (Sierra was the base model name in Europe), was technically a different chassis, it is extremely close to the "EricA X" platform that the Escort/Tempo use, almost to the point of it being a melding of Escort and Mustang.
    Yeah, I know I'm putting the thread a little off the rails with mentioning a drivetrain swap, but I would still love to see it done, just to see what terror would be unleashed on the world with such a short wheelbase car.
  18. dchawk81
    3,121
    793
    173
    I wasn't even talking about skills. Just tack welding stuff where it doesn't belong. lol
