Lift gate struts
Discussion in 'Escort Wagons' started by cwol97401, Feb 5, 2017.
  1. cwol97401
    cwol97401 FEOA Member
    348
    100
    103
    Midwestern Oregon
    Has anyone ever replaced their back door lift struts with a stiffer/stronger/ longer stroke set? I want to add some auxiliary lights (= more weight) to the rear window and bottom lip of the rear door. Mine are getting old and sometimes like to remind me they are old if the wind blows just right when I'm under the door. Also for the longer stroke, when my lift gate is open to the limit of the struts,. It's just slightly shorter than the top of my head. Wondering how to find a set with a 1/2" longer stroke so that I might get maybe another inch out of the door when raised.
    Tapatalk
  2. cwol97401
    348
    100
    103
    Midwestern Oregon
    Bump
    Tapatalk
  3. rbailin
    rbailin FEOA Member
    986
    199
    293
    It depends on whether there's any extra room for a longer strut body when the hatch is closed. (I don't own a wagon so I can't tell.) If there is, then you have to look thru the specs in a strut catalog for one that's 1/2" longer that has the same mounting ends.
  4. cwol97401
    348
    100
    103
    Midwestern Oregon
    I'll have to comprise a measuring device and check
    Tapatalk
  5. Mark Hedges
    Mark Hedges FEOA Member
    9
    Anyone else have the problem where the struts collapse when it's cold out? I am so tired of the lift gate falling on my head. :)
  6. cwol97401
    348
    100
    103
    Midwestern Oregon
    Struts wear out eventually. Sounds like yours have. New ones are not expensive and they are easy to replace.
    Tapatalk
  7. denisond3
    7,778
    1,542
    363
    I have a length of bamboo rod to hold up the lift gate - anytime its less than about 80f outside.
  8. Mark Hedges
    9
    Mechanic says new lift struts from Ford's secret stash are $40 a piece.
  9. dchawk81
    dchawk81 FEOA Member
    3,121
    793
    173
    Your mechanic is a shyster. Run Simba. Run away and never return.
    copcarguy likes this.
  10. cwol97401
    348
    100
    103
    Midwestern Oregon
    New struts can be had for $17 each new. And that's not even Amazon or eBay prices
  11. Joey_Twowagons
    Joey_Twowagons FEOA Member
    628
    146
    193
    Vancouver Island, Canada
    In Canada we use a sawn off chunk of hockey stick as a lift gate holder-upper.
    Ford should sell this piece of hockey stick as an approved service part.
    I'd replace mine, except that the captive nut in the body has broken free of its weld.
  12. novanutcase
    novanutcase FEOA Member
    1,476
    288
    143
    I got a brand new set for $25 plus shipping.
    John
  13. copcarguy
    copcarguy FEOA Member
    1,483
    535
    213
    Northeast PA
    Mr. Hedges:
    I have been curious if you have any updates if you still are in contact with this mechanic?
    I'm hoping you've found someone more honest to work on your car, and have resolved your taillight socket issue as well.
