Intermittent no crank no click
Discussion in 'Tech & Repair' started by Lizzie94, Feb 21, 2017.
  1. zzyzzx
    13,084
    622
    Recommend me a brand of replacement ignition switch (the electrical part).
  2. Lizzie94
    Lizzie94 FEOA Member
    272
    55
    28
    Personally I would go OEM.
    It did it again a few days ago, so the brush/armature thing doesn't appear to be the issue. I REALLY don't want to have to replace the ignition switch because it would involve yanking the steering wheel and that's a difficult and scary task. If I do have to replace it, then so be it. But I really hope it's not the problem. Not really sure what else it could be besides the switch or the relay.
  3. denisond3
    7,816
    1,580
    363
    You can change an ignition switch (on a 2nd gen at least) without steering wheel removal. Instead you remove the column clamshell, undo the 4 bolts holding the column up to the dashboard, and let the wheel drop into your lap. Then you can get to those pesky anti-theft bolts to unbolt the ign switch assembly from the car.
    cwol97401 and Lizzie94 like this.
  4. Lizzie94
    272
    55
    28
    Wow, that's awesome! Now I won't feel so bad about replacing the switch if I have to. Lol
  5. zzyzzx
    13,084
    622
    Mine is acting up again. It starts before I get to the starting position, sometimes.
  6. zzyzzx
    13,084
    622
    OK, you you are recommending the Standard Motor Products US301?
  7. cwol97401
    cwol97401 FEOA Member
    367
    114
    103
    Midwestern Oregon
    Third gen is identical process
    Tapatalk
    Lizzie94, zzyzzx and denisond3 like this.
  8. zzyzzx
    13,084
    622
    If you look at the pictures of the Motorcraft switches in eBay, they say made in Taiwan. I'm not impressed!
  9. Intuit
    Intuit FEOA Member
    6,998
    671
    313
    Southwest Ohio
    Rebuilt stuff is made any and everywhere. I had a crap rebuilt alternator and virtually nothing about it was Motorcraft except the casing.
    zzyzzx and Lizzie94 like this.
  10. Lizzie94
    272
    55
    28
