Here I go again...
Discussion in 'Auto-biography' started by schwinnman67, Jun 24, 2016.
  1. schwinnman67
    schwinnman67 FEOA Member
    289
    61
    88
    Colorado
    Just as I'm getting my other 98 ZX2 in decent running shape, I pickup another one..
    I just got a 2002 ZX2 with a bad ATX. This car may end up being my girlfriend's 17 year old daughter's first car. I only paid $200, so I can do some things to it. I have a transmission located. The body isn't too bad, needs a rear bumper cover, driver's mirror and a headlight (water in it).
    I'll post some pics soon....
  2. schwinnman67
    289
    61
    88
    Colorado
    Transmission is supposed to be here today, juts need to het it installed...
  3. schwinnman67
    289
    61
    88
    Colorado
    Got the transmission installed and it's perfect. Now just need to do a timing belt, radiator, thermostat housing, rear brakes and parking cables.
    This is a weird one to me, it has rear drums and ABS.
  4. pextor
    pextor Moderator Staff Member
    4,755
    314
    233
    Lancaster, pa
    my current 99 sedan has drums and ABS. I had two ZX2s with drums and ABS.
  5. schwinnman67
    289
    61
    88
    Colorado
    Pulled the front bumper to change the headlights and found that it had been wrecked on the left side. Looks like 3 hours labor on a frame rack to get it straight....
  6. schwinnman67
    289
    61
    88
    Colorado
    I've seen ABS only on sedans with 4 wheel discs (I used parts from one to convert my Blue 98 ZX2)... Never had one with ABS until now.
  7. Pizzaman5000
    Pizzaman5000 FEOA Donator
    1,149
    269
    93
    Central OH
    Oh man.
  8. schwinnman67
    289
    61
    88
    Colorado
    All straight now... Time to get the rear brakes and cables done...
  9. schwinnman67
    289
    61
    88
    Colorado
    Finally got it emissions tested, passed with no problem. Got a decent silver rear bumper, so now it looks decent. Now all the mechanical stuff (timing belt, radiator, water outlet, struts and upper oil pan gasket)...
    Pizzaman5000 likes this.
  10. schwinnman67
    289
    61
    88
    Colorado
    Starting on the mechanical. Have the upper oil pan pulled, just need to get it (and a few other parts cleaned). Learned that doing the oil pan on an ATX is a pain compared to the MTX. You have to pull the right axle to get the pan out....
  11. schwinnman67
    289
    61
    88
    Colorado
    Now that I have the oil leaks sealed up (upper oil pan and sending unit) I have done the timing belt. Also replaced the radiator (leaking) condenser (fins are flat) and changed the leaking water outlet to a 98 style.
    Now it's time to do struts, ball joints and an alignment. Hope to get this to my lady's daughter soon...
  12. schwinnman67
    289
    61
    88
    Colorado
    Finally in the finishing stages..... The mechanical is done, what a list
    Used transmission
    struts
    ball joints
    rack
    front brakes and rotors
    rear brakes and new adjusters
    parking brake cables
    radiator, water pump and thermostat housing
    timing belt
    serp belt idler pulleys and tensioner
    condenser
    muffler
    and appearance
    rear bumper
    both mirrors
    headlights
    park lights
    re seal spoiler to trunk
    rear mud flaps (still looking for a front set)
    new stereo
    frame straightening
    Goes for detail Friday and then off to the GF's daughter in college......
  13. schwinnman67
    289
    61
    88
    Colorado
    The 02 has a new driver..... She is very happy to have a car now. I drove the car for 2 weeks before she got it, so hopefully there should be no problems... 2016-11-06b 2002 Ford ZX2 Silver.JPG 2016-11-06a 2002 Ford ZX2 Silver.JPG
  14. Gamer92
    Gamer92 FEOA Donator
    2,941
    766
    213
    Southern Indiana
    [​IMG]
    [​IMG]
    This is a 99 tracer with front discs and rear drums. It has abs
    I think the tracers received all the abs systems and such
  15. schwinnman67
    289
    61
    88
    Colorado
    Saw a 98 ZX2 with abs and drums today in the pull and save..
