Gimmie some tip on lower rad hose replacement.
Discussion in '2nd Gen 1991-1996 1.9L SOHC' started by Not THAT kind of 'escort', Mar 18, 2017.
  1. Not THAT kind of 'escort'
    Not THAT kind of 'escort' FEOA Donator
    174
    22
    78
    I remember looking at it on my 95 and saying "screw that, I'll have him do it when I get clutch and timing job".
    I also remember needing to tear half the motor apart to do the lower hose on an 88 Tracer (323).
    I'm planning to do radiator, hoses and serpentine belt on my 1992 5spd.
    Any recommendations on radiators? Current factor plastic sided one is leaking....from the PLASTIC....after return from stolen.
  2. cwol97401
    cwol97401 FEOA Member
    266
    73
    88
    Midwestern Oregon
    The lower hose is a bitch to get to but not impossible. It might be easier with a helper. When I did mine, I had the PS pump and ac compressor removed. It was easy that way. On another one, I removed the alternator and put the hose on blind. There is space to see the water pump outlet behind the accessory bracket with the alternator out. Put a helper under the car to feed the hose to you as you guide it into place. Good luck.
    Tapatalk
  3. denisond3
    7,718
    1,513
    363
    If you have the serp. belt tensioner removed, it gives you a decent view of where the hose fits on the water pump. This helps with getting a clamp on there, and installed fully and square. Having the hose warmed up in hot water might also help.
    zzyzzx and copcarguy like this.
  4. Not THAT kind of 'escort'
    174
    22
    78
    thx, I guess if I'm doing the snake belt I might as well do the tension-er.
  5. zzyzzx
    12,990
    591
    Radiator hoses can go bad on these cars???
    cwol97401 likes this.
  6. Maxwelhse
    Maxwelhse FEOA Member
    707
    152
    53
    If I remember right (which is asking a lot... this would have been in 2008) when I did it on our 93, I just took the timing belt cover off, jimmied the clamp down the hose, and used a big pry bar to push it off of the water pump. I usually put a little grease inside the new hoses to help them slide on so I'm sure I just greased it up and stuffed it back on the pump from the radiator side. I'm pretty sure I didn't take any accessories off to do it. The '95 Pony I replaced when I did the water pump and timing belt so that was a no brainer process.
    As far as radiator, I put an Advanced Auto cheapie in the Pony about 18 months ago and I don't have any complaints. I think it's been in there for about 25,000 miles now. With their online promotions at the time I think I paid $52 for it, out the door, with a lifetime warranty. It doesn't leak, fits great, and the car doesn't get hot. Not much more to ask out of it than that. I think at that price it even has a trans cooler in it.
    denisond3 likes this.
