Evapo-Rust Cooling System Cleaner
Discussion in '2nd Gen 1991-1996 1.9L SOHC' started by 91WhtScort, Oct 2, 2011.
  1. 91WhtScort
    91WhtScort New Member
    101
    I used this stuff today and I'm pretty sure it cleared out a bunch of rust.
    When I got the wagon, I cleaned up the water outlet housing (got the plastic bullet moving freely) and put in a new t-stat (the old one was pretty much rusted away). I could see a bunch of rust clinging to the insides of the motor. I did not want to use a harsh flush and I have no hose available where I park it.
    I bypassed the heater core, as I knew it was pretty much clogged up and installed a new radiator after a few drains and fills of coolant. I installed my new heater core this week (not hooked up yet) and now it was time to tackle the crud in the block before installing new hoses and hooking up the heater core.
    I decided on the Evapo-Rust stuff because they say it will not harm anything, is non toxic and from past experience with regular Evapo-Rust on rusted tools and stuff.
    [​IMG]
    I drained the sytem and loaded it up with the quart of cleaner and distilled water. I let it run for an hour (per instructions) then after a sufficient cool down, drained the mix. P U did it STINK!! Smelled strongly like sewer or rotten eggs (take your pick) and was just about black. It went in crystal clear. The black is the converted rust.
    [​IMG]
    I did two subsequent fills and drains with just distilled water and the mixture came out less black each time. I finally filled it back up with 50/50 Green Zerex and distilled water. I'll run it a day or so like this and do one more drain and fill and get the heater core going again.
    Anyway, until I change out the water pump (next project somewhere in the near future), I guess I will not know just how clean it got, but I KNOW it HAS to be atleast 50% cleaner than it was.
  2. mazarnelli
    mazarnelli FEOA Member
    23
    31
    Arkansas
    Where did you buy the cleaner at?
  3. 91WhtScort
    101
  4. mazarnelli
    23
    31
    Arkansas
    I'm going to give this stuff a try because my system was pretty rusty so I bought a flush kit and flushed about five times and used the Prestone Super Flush and it's still not as clean as I expected.
  5. 91WhtScort
    101
    Great! If you do it, give us a complete run-down, please!
    Yeah, since rust is the foremost contaminant with our iron blocks, the other flushes that are not 'rust only' like this stuff, really ain't gonna tackle the real problem.
