Clutch Master Cylinder Replacement
Discussion in '2nd Gen 1991-1996 1.8L DOHC' started by chrmar, Mar 15, 2008.
  1. chrmar
    chrmar New Member
    200
    Nerepis, NB
    So, the master cylinder for my clutch has decided to fail. I checked the board for my symptoms and the result was agreement with the shop I checked with about the problem. Anyhoosers, what I'm wondering is how specific this part is. Can I get one from any old 91-96 Escort? Or does it have to be a GT? How about from a 1.8L Protege? The shop wants $180 to install the thing, with $80 being for the part itself (I might have to break down and buy a new one if I can't get one from a junkyard). Figured I'd check with compatibility first. Thanks!
  2. jinx
    jinx New Member
    1,090
    Palm Beach County, Florida
    It's not hard to change out at all. 2 nuts, one on the inside by the pedal and the other one on the firewall behind the strut tower, 1 hose thats on with a clamp ring, and the steel curly line running towards the slave. You can pick a new one up at autozone or advance for about $40-80.. Then all you gotta do is bleed the system and adjust your pedal as needed. Pretty easy 8) Definitely not worth $180 for someone else to install, unless you're not into fixing your own car.
    Ford
    1991 - 2002 ESCORT
    2000 - 2003 ZX2
    Mazda
    1990 - 1994 323
    1992 - 1995 MX-3
    2003 - 2006 6
    1990 - 1998 PROTEGE
    1991 - 1999 TRACER
  3. chrmar
    chrmar New Member
    200
    Nerepis, NB
    Ah excellent, lots of availability then. No Autozone up here; the $80 for a new one is from an auto parts store.
    I'm all for doing the work myself, but I have zero time in which to do it these days. :(
  4. jinx
    jinx New Member
    1,090
  5. chrmar
    chrmar New Member
    200
    Nerepis, NB
    Mm, maybe... but I'd prefer to get this car driveable ASAP. To go to uni I need to go through a lot of traffic and stopping on hills, none of which is advisable with a busted drivetrain.
    Has anyone replaced this part? Can anyone give me an idea on ease of swapping?
  6. jinx
    jinx New Member
    1,090
    It's very easy bro. The most time will be spent bleeding the system.. You can get the whole unit out in under 45mins. If you need pics let me know :D
  7. chrmar
    chrmar New Member
    200
    Nerepis, NB
    Pics might be helpful. You can send them in a PM, if you like. Also, for bleeding the system is it a similar procedure to bleeding the brakes?
  8. jinx
    jinx New Member
    1,090
    Np, I'll take some pics when I get home. Bleeding is a tad different from the brakes but basicly the same. It's alot easier to get air out of the brake lines then the clutch lines.
    General idea of what you will be doing below
    [​IMG]
