cheap cellphone dash mount for 2nd gen?
Discussion in 'Interior Modifications' started by needWheels, May 6, 2012.
  1. needWheels
    needWheels FEOA Member
    520
    4
    118
    I recently discovered the free Torque android app and the $10 wireless bluetooth odb2 device from fleabay. Works nice.
    But I'd like to stick the phone on the dash to watch mpg and even my speed since I have the 96 bouncy speedometer above 45mph
    Other than slapping some velcro on the back and the dash, is there a better cheap way?
    added: do those anti-slip pads actually work? I see some demos with devices at over 90 degrees http://www.ebay.com/sch/i.html?_nkw=Dashboard+Slip+pad
  2. Anomalous
    Anomalous FEOA Donator
    534
    6
    268
    i dont think you will find antyhing particularly cheap, there are mounts out there, check out Rammounts.com they have mounts for just about everything, but they are a little pricey. best thing to do is just keep an eye out at the stores what will work for your application.
  3. needWheels
    520
    4
    118
    I ordered one of the magic sticky pads for $2 to see what they are like and if they stick to the escort dash or not.
    My phone is in a plastic case so that should help the stickiness, hopefully with zero residue as I peel it off repeatedly.
  4. RedSE
    RedSE FEOA Member
    268
    8
    28
    Coeur d'Alene, ID
    Wal-mart has a mount that snaps into your air vent for fairly cheap, and it works pretty good.
  5. needWheels
    520
    4
    118
    It gets super hot here, need those air vents 100% open and clear :)
    I am going to try to find a suction one with good reviews on amazon.
  6. RedSE
    RedSE FEOA Member
    268
    8
    28
    Coeur d'Alene, ID
    Your phone might have a window mount made for it. Check ebay.
  7. Butler854
    Butler854 FEOA Member
    106
    36
    Missoula, MT
    I have one of these and it has worked greatly for delivering and the Dyno apps I have. You might want to look for one more specific to your phone, but that one expands pretty widely, so it should be a pretty universal fit.
    Pic related
    [​IMG]
  8. needWheels
    520
    4
    118
    Cracked windshield (very common apparently on 2nd gen as my wagon also had it) so I don't want to put any more stress on it.
    Going to wait for a sale on one of the more highly rated (and more expensive) suction cup holders and attach it next to the blank space next to the vent/rear defrost button.
  9. Butler854
    106
    36
    Missoula, MT
    True, mine's got a crack all the way across from attempting to remove the mirror, lol. But that one also comes with a base that has a sticky side, and a smooth side so that you can stick it anywhere, and then use the suction cup to hold it down.
  10. cwol97401
    cwol97401 FEOA Member
    261
    70
    88
    Midwestern Oregon
    Never attach a solar panel to a battery without a charge controller. It's the best way to force yourself to buy a new battery. The cheapest and safest way to do it is with a $20 harbor freight controller like this one:
    https://www.amazon.com/Sunforce-7-Amp-Charge-Controller/dp/B0006JO0XI
    Tapatalk
  11. novanutcase
    novanutcase FEOA Member
    1,406
    267
    143
    I found a wireless charging cradle that suction cups to either the dash or the windshield. I mounted it just above the A/C drivers side vent to keep my front vision as unobstructed as possible. I plan on installing a USB power port on the plastic panel that goes around the steering column so that I can run a shorty fast charge cable. For some reason USB charge cables tend to stop working after a while once they get in my hands so I need to be able to change out the cable quickly instead of having to pull the dash apart to get to the offending cable.
    John
