About to take the head off
Discussion in '1st Gen 1981-1990 CVH' started by Zane, Feb 12, 2017.
  1. Zane
    Zane FEOA Member
    8
    Hello feoa, I'm pretty new to the DIY mechanical scene and I bought my 88 escort back in October of 2016 and never got around to fixing all of the problems until just recently. The biggest problem right now is I suspect a blown head gasket so I'm about to take the head off. I'm planning on replacing the head and valve cover gasket along with the timing belt and thermostat. What else should I check/replace?
    denisond3 likes this.
  2. denisond3
    7,816
    1,580
    363
    I have fixed up eight 2nd gen Escorts, for myself and family members. For three of them I had the machine shop mill .006" off the top of the block, to clean up areas that had black rust. I wanted a shiny surface that was truly flat, for the replacement head. I also use a thread tap to clean out all the holes in the blocks, and the same for the threaded holes in the heads. I have a 14mm thread tap that I use to clean up the spark plug holes, but that probably would not be needed with a rebuilt head.
    I am glad hat you are fixing up a first generation Escort. They are a worthy car. I just started with the 2nd gen Escorts (my first one was given to me), and decided to stick with them.
    Zane likes this.
  3. Zane
    Zane FEOA Member
    8
    Thanks for such a fast reply desnisond3! I love how the escort looks and drives and I want to make this a possible 300k+ mile contender. It's at 127k right now. Is it hard to take the head off? It doesn't look too challenging because there isn't much in the way. Do you have any tips for popping it off easier?
  4. denisond3
    7,816
    1,580
    363
    I like to take pictures with a digital camera, shooting lots of pix, and taking more of them as I have parts off and out of the way.
    Mine are all 2nd gens, but my preference is to remove both the intake and exhaust manifolds, since that takes off enough weight that the head itself is an easy one man lift. When you have the head bolts out and the timing belt removed, you will likely still have to pry the head up slightly. This breaks the bond between the dowels that line up the head with the block. Dont lose them, they arent easy to find replacements for. I always have a couple of boards ready to set the head on. This is because a couple of the valves will be sticking down below the plane of the head, until the rockers arms are undone anyway.
    Depending on how far apart you have the car, I would recommend you replace the freeze plugs in the block if you possibly can. With the 2nd gen blocks there are five freze plugs. Two of them on the front side of the block, two on the backside, and a larger one on the end that you can only reach once the engine is separated from the transmission and the flywheel is removed. I havent had leaks from the freeze plugs yet, though a couple of them were beginning to seep. With engines as old as ours, I figure the freeze plugs dont have much longer before they will leak.
    I use new head bolts when I reassemble. I take two of the old head bolts and grind down the hex head and the flange to be the same diameter as the shaft. Then I thread the two bolts into the block a couple of turns. This gives me a pair of guides for lowering the head down onto the new head gasket and the locating dowels, so I dont get any gouges on the gasket. Then its easy to unscrew the 'modified' head bolts.
  5. Joey_Twowagons
    Joey_Twowagons FEOA Member
    638
    149
    193
    Vancouver Island, Canada
    "About to take the head off"
    Oh, thank God. I was afraid this was going to be some awful ISIS beheading video.
  6. denisond3
    7,816
    1,580
    363
    And welcome to the forums Zane!
  7. robynhoods
    robynhoods FEOA Member
    322
    266
    USA
    have you started the car?
    have you done a compression test? if not do it be for you take the head off.
    are you losing antifreeze?
    the head is not awful but its a big job to do just starting out. pick up a manual it will help out a lot.
  8. Zane
    Zane FEOA Member
    8
    The car starts but runs terribly with coolant in the rad. I left the rad cap off and it bubbled out within a few seconds of starting and white smoke was pouring out of the exhaust. I'm pretty sure it's head gasket. Right now I have the intake and exhaust manifolds off, with detailed notes so I remember how to do it lol all I have to do is take the belts off and then dive into the engine. It's going pretty well. I've had to take a few trips to the hardware store for a deep socket 1/2 and some other goodies. I can't seem to figure out how to release the tensioner? There isn't a bolt head on it.
  9. denisond3
    7,816
    1,580
    363
    Cant help with how to release tensioner. Have never worked on a first gen Escort.
  10. JOEG5982
    JOEG5982 FEOA Member
    242
    34
    178
    The Tensioner? Loosen the two bolts (one is not easily accessible when blocked by a motor mount) and wedge a pry bar on one end to slide it over and while doing that, retighten one of the bolts so it holds position.
    Zane and denisond3 like this.
  11. Zane
    Zane FEOA Member
    8
    Thanks guys! I got the head off and damn! The gasket was not in good shape valves.jpg pistons.jpg head gasket.jpg
  12. denisond3
    7,816
    1,580
    363
    In your photos, the darkened areas on the head seem to be mostly around that front-driver's-side corner, as well as that area of the gasket. I have found that particular head bolt is the one that had rusty threads (or snapped on removal) on several of my rebuilds. And on 3 of my rebuilds so far, I got the block milled down a few thousandths, just because I didnt like some much darkening on one region. Nor did the machinist. Afterward, the entire top of the block was shiny and light colored. Of course it means the block has to come out of the car – but I felt it was worth it. He milled off about .006” or .007”.
    It might be the kind of procedure that needs to be done to the engine once every 20 to 30 years; which means few mechanics are likely to be expecting it.
    The darkened portion of the fire ring of that cylinder #4 also indicates there had been a looseness there for a while. The color of the fire ring at the 10:00 is what they should look like.
  13. Zane
    Zane FEOA Member
    8
    Thought I'd give you guys an update.
    I enlisted the help of my dad because I helped him install a water heater at his house so he owed me some labor so in about 4 hours we got almost everything back together. I'm going to get some new spark plugs and wires because the old plugs were slightly fouled. The new gaskets are pretty cool. I used some hi-temp joiner compound just to be safe and the intake and exhaust are back on. All I have to do is fill the rad and put the air cleaner on and then I can fire it up! I've learned so much in these past 2 weeks and can't wait to find a new project. Thanks for all the help!
  14. Joey_Twowagons
    638
    149
    193
    Most modern head gaskets include instructions to install without any additional sealer, but I suppose a thin layer shouldn't hurt.
    Oil or coolant fouled plugs will rapidly burn clean when run in a properly tuned engine.
  15. Zane
    Zane FEOA Member
    8
    The instructions didn't say anything about it so in my mind it was just an extra preventative layer. Thanks for the tip about the spark plugs! That'll save me a few dollars!
  16. Zane
    Zane FEOA Member
    8
    So now I'm having a problem with the radiator drain cock popping off when I start the car. Should I leave the radiator cap off when I first start the car? This happened twice
  17. Intuit
    Intuit FEOA Member
    6,998
    671
    313
    Southwest Ohio
    Old H-Gaskets were designed on the principal of sticking. But the aluminum head expands IIRC 5 times faster than the iron block. Once in the field, manufacturers quickly found out that the headgaskets were getting destroyed.
    So, modern head gaskets took the opposite approach, and are designed with special coatings that make them slick and durable under high pressures.
    Bottom line, don't use sealants on your h-gasket.
  18. Zane
    Zane FEOA Member
    8
  19. Joey_Twowagons
    638
    149
    193
    I'm sure it will be fine. That aerosol will provide only a very thin layer of sealer. In the video the stuff was used on a metal faced exhaust manifold gasket, probably a more appropriate application of it.
  20. JOEG5982
    242
    34
    178
    I'm more concerned about your radiator. Sounds like the drain is broken.
