Exhaust 97 escort lx header
Discussion in 'Engine Tuning' started by Alexdkk, Apr 4, 2017.
  1. Alexdkk
    Alexdkk New Member
    4
    Hey,
    I was wondering if this header would fit on my 97 escort
    https://www.amazon.com/OBX-Performa...1491369686&sr=8-2&keywords=ford escort header
    It's an OBX, which I am not a fan of, but I believe if I read on the forums correctly the 1.9l header should fit on my 2.0l, but will have to be modded some to fit. I was just wondering if that was correct or if I should just look for something else entirely?
    Thank you in advance.
  2. Tnashua
    Tnashua Gearhead / hot rodder with a soft spot for Scorts
    787
    151
    103
    Oskaloosa, IA
    Should, but the gains will not be as great as with a properly paired 4-2-1 header...
    Gotta run- Or I'd provide more detail- save your $ for now...
  3. Alexdkk
    Alexdkk New Member
    4
    Alright thank you! You have any idea where I might be able to find the right one? I figure it is probably like finding a needle in a haystack with these cars ahaha
  4. Tnashua
    787
    151
    103
    Oskaloosa, IA
    The headers below are all Stainless Chinese knock offs of the OBX ZX2 header. The cheapest of which is the top link. I have no experience with them. Perhaps someone else on here has?!. The tube spacing (at the head) should be the same as the SPI, but the bolt pattern is different- so if you wanted to use any of them- you'd have to get someone to replace or modify the flange. There are non-stainless ones on there too, but they really aren't much cheaper. These headers would require less modification than a 1st gen GT header & would probably flow about the same (maybe better flow- not sure on the scavenging) ... You could build your own, but you're going to spend as much money on bends & O2 sensor bungs as you would on the steel headers & then you have a ton of cutting & welding to do. Either way- you'll need to modify your secondary O2 sensor to avoid constant codes.
    http://www.ebay.com/itm/STAINLESS-S...ash=item5d66610dec:g:MmQAAOSw4A5Yt5st&vxp=mtr
    http://www.ebay.com/itm/Stainless-S...ash=item4b0de7a8fe:g:2ZIAAOSwa~BYTGlz&vxp=mtr
    http://www.ebay.com/itm/FOR-98-02-F...ash=item236d4f1863:g:H7AAAOSwzaJX9s6Q&vxp=mtr
    http://www.ebay.com/itm/STAINLESS-R...ash=item2ef1185bfd:g:AcgAAOSwCGVX99N7&vxp=mtr
    http://www.ebay.com/itm/FOR-98-02-F...ash=item43fb063368:g:AiUAAOSw5cNYVI2m&vxp=mtr
    Alexdkk likes this.
  5. Tnashua
    787
    151
    103
    Oskaloosa, IA
    Alexdkk likes this.
  6. Alexdkk
    Alexdkk New Member
    4
    Ima look into all of these and consider it before I make a decision. Thank you for the insight and overall information
