2002 Ford Escort ZX2...idling issues (high idle??? wtf)
Discussion in 'Tech & Repair' started by TylerSanderson, Feb 21, 2007.
  1. TylerSanderson
    TylerSanderson New Member
    I drive a 2002 escort zx2
    Car's been perfect until now, just started to idle really high. In drive/reverse/etc it idles around 1100-1200 rpms, sometimes higher... and when in park/neutral its up in the lower to mid 2k range. WTF?
    Can't seem to figure out what's wrong. I unplugged the IAC and nothing happened but the CEL came on... so I take it thats working. I just can't seem to figure the problem out. No vacuum leaks though.. its wierd. :?:
  2. Newfie_dan
    Newfie_dan New Member
    1,158
    Saskatoon, Canada
    checks
    check for any leaks in the air intake tube with carb cleaner, if thats not yeilding any results then look for engine codes possibly a tps problem, I would also clean the IAC valve and maf to ensure that these are elimintated as sources of your problems.
  3. zzyzzx
    12,861
    551
    Check for vacuum leaks. Get a MityVac to do this.
  4. jlongoria9
    jlongoria9 New Member
    4,247
    Texas
    sticking IAC
  5. pyro_maniac69
    pyro_maniac69 New Member
    749
    are you sure your car is warming up? sounds like the computer doesn't know that its warm and is keeping the idle high
