2000 zx2 hood wont open!
Discussion in 'Tech & Repair' started by redscort, Nov 17, 2007.
  1. redscort
    redscort New Member
    23
    Cleveland,OH
    Hi, Is there anyone that knows how to adjust or fix the hood release lever on a 2000 zx2? The only way to get it open is if someone pulls the lever while I pull on the hood. Any help is appreciated THANKS
  2. crazycarl88
    crazycarl88 New Member
    1,335
    evansville, in
    wd40 the latch... probably all it needs.
  3. redscort
    redscort New Member
    23
    Cleveland,OH
    It seems like there is a lot of slack in the cable
  4. zzyzzx
    13,084
    622
    The cable may have stretched. It can be replaced (not easily, but it can be). I would use something better than WD-40 though. I'd use a thicker grease.
  5. jigsaw
    jigsaw New Member
    1,803
    ur problem is that the hood latch has moved down. u need to loosen the bolts and then move it up a little and re-tighten the bolts. also, if u look on the fender side (bottom circled item on pic) u will see some rubber screw things, u can unscew those a few turns out. this will provide the pressure needed to pop the hood.
    here is a pic:
    [​IMG]
    hope it helps
